Synthetic oil vs. Regular oil
Old Oct 9, 2003 | 07:30 AM
  #46
StudlyMobile's Avatar
Re: Synthetic oil vs. Regular oil
if i don't drive my G hard and only put 4-6k on it per year,
1. reg or synthetic?
2. how often?
thanks. i am mechanically inclined though engine ignorant.
04 6mtC
Old Oct 9, 2003 | 11:31 AM
  #47
ryoken's Avatar
If you only drive your car 6,000 miles per year, then time will be your enemy. Odd as it may seem, short trips and lack of use can cause more problems in a car than heavy use. You may want to follow Schedule 1 in the maintanence manual, which you'll note requires an oil change every 3,750 miles or every 3 months, whichever comes first. The rest of the maintanence schedule has months associated with the intervals as well as mileage. The manual has a list of criteria in it to decide whether to use Schedule 1 or 2. Even if you go with 2, don't go far past the month timelines just because you haven't accumulated the mileage.
Note that some synthetics, such as Amsoil (I'm not sure about Mobil1 -- didn't read the whole bottle before throwing it away), allow you to go up to a full year before needing to be changed (time-wise). Otherwise, you'll be changing your oil every 3-6 months, depending on the service schedule. From a cost standpoint, regular oil will still be cheaper. From a be-good-to-your-engine standpoint, I don't think you're running it hard enough to worry about, either way.
Old Oct 9, 2003 | 08:45 PM
  #48
chinee's Avatar
Studly...ask your question over at www.bobistheoilguy.com ... you'll probably get an answer similar to ryoken's but with much more detail.
<font color=red>chinee</font color=red>
03.5 G35s
Old Jan 29, 2004 | 01:37 AM
  #49
ClevelandGuy's Avatar
Great point! I had a Mitsu that had cold weather start noise; just a trait of the engine, and I switched to a 50/50 mix of synthetic and dino and the noise practically went away. Using it on my new Mivec engine now. How can people be concerned about spending extra money on oil anyhow? Blows my mind......or are they so cheap that when they walk they squeak ?
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
Learned Hand
Oct 1, 2015 09:02 AM
9tray turbo
Sep 29, 2015 10:22 PM
