Removing Resonator
Old Apr 21, 2006 | 05:40 PM
gojc's Avatar
Removing Resonator
I was at a local muffler shop asking about new exhausts/mufflers etc. and they recommended that I remove the resonator and put in a straight pipe. Anyone know what would happen if I did this?
I've got an 05 Sedan...
Old Apr 21, 2006 | 06:03 PM
Xman's Avatar
You would lose about 30 lbs and the car would sound louder. If you get another muffler like an HKS it would sound even louder. My $0.02 FWIW.
Old Apr 21, 2006 | 08:46 PM
Loe G35's Avatar
It will drone as well between 1,500-1,700rpm.
Old Apr 21, 2006 | 09:52 PM
godmans's Avatar
try sth like a straight thru resonator?
Old Apr 22, 2006 | 02:58 PM
gojc's Avatar
I ended up removing the stock resonator and putting on a Magnaflow resonator. I kept the stock muffler. I think it sounds pretty good...basically just enhanced the stock sound. I think the other pluses are it is much lighter than the stock resonator and flow is a little less restrictive. Total was a $100 out the door.
Old Apr 22, 2006 | 03:24 PM
Neal376's Avatar
that sounds like the best way to go about it. I planned on doing that awhile ago. Is it deeper, louder, raspier? Make us a sound clip.
Old Apr 22, 2006 | 03:30 PM
99atlantic's Avatar
this is what happens when u pull it on the coupe, no idea about a sedan - http://videos.streetfire.net/search/...119B56414B.htm
Old Apr 22, 2006 | 08:44 PM
gojc's Avatar
Actually, they removed the stock resonator initially and put in a straight pipe, it sounded raspy and I didn't care for it. So, they put in the Magnaflow resonator and it basically took care of the issue.
The sound is deeper at all rpm's...it's kind of hard to describe but I would say it is a deeper version of the stock sound. Doesn't completely change the stock sound like a new muffler would, just enhances what you already have.
Regarding the sound clip, I don't have the equipment to do that right now...also, I don't think sound clips actually help much. I think trial an error regarding sound works best.
Try going to your local shop and see if they will make you a deal, if you don't like the sound coming out with the new resonator, see if they will weld the stock one back on included in the original quote.
If you do decide to do it, let us know what you think...I really like mine.
Old Apr 23, 2006 | 12:24 AM
Neal376's Avatar
ok, so its confirmed. Removing the stock resonator creates rasp. Pre Mufflers are meant to absorb high pitched noise, so it really is not much of a surprise. Alright. I think I will do that, get a magnaflow.
Old Apr 23, 2006 | 12:55 AM
gojc's Avatar
For me, it was the way to go. I was going to go with a full cat back exhaust but for 7-8 rwhp, (according to several dynos on this forum) it wasn't worth it. I still wanted a fuller exhaust note and this option worked. If the dynos on the (to be created) Fast Intentions exhaust for the sedan show significant rwhp, I might go that route. But for now, this works...
Old Apr 24, 2006 | 07:11 AM
JustBrilliantX's Avatar
Misanthropic nut-cracker
From: On the water at the "Jersey Shore"...Toms River
What did you think about the all the variables when ya checked out the search engine under Mid-pipe or middy?
Old Apr 25, 2006 | 04:19 PM
RX7_schlep's Avatar
I've tried using the Magnaflow 22" resonator with the stock muffler on my 5AT G35 and had noticable droning at ~2200 rpm. After about 2 weeks I removed the Magnaflow and went back to the stock resonator since 2200rpm was around where the rpms sit when cruising around town or on the highway but YMMV.
Old Apr 26, 2006 | 01:36 AM
gojc's Avatar
For some reason I don't notice the drone. I drive from the Sacramento area to the SF Bay area once a week and there was no difference for me on the hwy. I don't think they installed the 22" resonator on my car...it seemed shorter actually. The one thing I notice about these forums is really...to each his own...
Old Apr 26, 2006 | 10:45 AM
Loe G35's Avatar
My 18" resonator droned at 1,500-1,700rpm. I have since replaced it with a coupe middy. It still drones, but its not annoying or loud and is acceptable.
Old Mar 30, 2017 | 12:33 AM
Blue Dream's Avatar
I drove ttrank's car solo
lolol gojc hasn't logged in here in over 7 years, plus he wasn't talking about replacing the muffler like the vid you posted. He was talking about replacing the stock resonator but thanks for trying to be helpful.......
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
dcsbh1
Oct 1, 2015 03:15 PM
