350z Springs Alignment ?- need some help out of the rough
Old May 17, 2006 | 02:47 PM
BigSash's Avatar
no align to specs for your model
Old May 17, 2006 | 03:36 PM
Jeff92se's Avatar
Red Card Crew
The only specs you have real control over is the toe and MAYBE the camber to a very slight degree.
It also depends on what YOU want. Z specs are by nature a bit more agressive
Originally Posted by junbug
Let me ask the question another way... It's been established that with the 350Z springs we can get close to factory specs for the sedan. but if we have the 350Z springs, would we WANT to align based on the 350Z specs?
Jun
Old May 17, 2006 | 08:38 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
Here's the factory specs for the 04-05 sedans with sport suspension:
Front:
Camber: -0.8/0.7
Caster: 7.0/8.5
Toe: 0.00/0.08
Rear:
Camber: -1.1/-0.1
Toe: 0.00/0.22
Specs after installing 05 350Z springs and before the alignment:
Front:
Left: Right:
-1.2 Camber -1.2
8.0 Caster 8.4
-0.01 Toe -0.14
Rear:
Left: Right:
-1.0 Camber -1.4
0.19 Toe 0.32
Specs after alignment:
Front:
Left: Right:
-1.2 Camber -1.2
8.0 Caster 8.4
0.05 Toe 0.04
Rear:
Left: Right:
-1.1 Camber -0.9
0.08 Toe 0.09
-GP-
Old May 17, 2006 | 11:24 PM
Tunerz_Store's Avatar
https://g35driver.com/forum/showthread.php?t=86103
Old May 19, 2006 | 08:20 AM
vrsc's Avatar
So would it be Ok to have my 2005 Non-sport sedan lowered on a full 2005 Z suspension aligned to the Sport sedan specs??? I am getting it aligned in a couple days and would like to direct the shop, so please assist
Old May 19, 2006 | 12:20 PM
YES it would be OK to get it aligned to the stock 05 sport sedan specs. If you have it aligned to the 350Z or coupe specs it will just be a more agressive setup.
-GP-
Old May 19, 2006 | 06:40 PM
vrsc's Avatar
GP, thanks
Old May 23, 2006 | 06:11 PM
vrsc's Avatar
My alignment update:
Specs after installing 05 350Z full suspension and before the alignment:
Front:
Left: Right:
-0.8 Camber -1.5
8.3 Caster 9.3
-0.01 Toe 0.00
Rear:
Left: Right:
-1.5 Camber -1.3
0.12 Toe 0.04
Front:
Left: Right:
-0.9 Camber -1.4
8.3 Caster 9.3
0.05 Toe 0.05
Rear:
Left: Right:
-1.0 Camber -1.0
0.07 Toe 0.10
How are these specs? They mentioned that I should purchase a Camber kit, but I just said no
Old May 23, 2006 | 11:55 PM
Those numbers look good vrsc.
-GP-
Old May 24, 2006 | 12:28 AM
Foo_G's Avatar
Florida G35 Club, Premier Member
From: Universe.Milkyway.Solarsystem.Earth.NorthAmerica.USA.FL.Tampa
from the book
Attached Thumbnails 350z Springs Alignment ?- need some help out of the rough-alignment-specs.jpg
Old May 24, 2006 | 01:14 AM
StarChamp's Avatar
Jun
Not claiming to be an expert, but I'm pretty sure you want to align using the G35 Sedan specs, not 350Z specs. The G specs are derived from the longer wheelbase, and narrower track of the sedan, and you'll want to maintain those as closely as possible to minimize tirewear and keep the steering geometry.
Old Jun 21, 2006 | 08:10 PM
mikeee2's Avatar
Hi...
I had my X lowered last week with unrevised z springs. I called up a shop today to ask for the alignment price. They asked if my car has been lowered and I gave them the details. They said since it's lowered now, they can't do the alignment for me even if I bring the specs to them. They said I need to go back to factory. Reading from this thread, it's telling me otherwise. Can I just go to an alignment shop and give them the below specs and have them align it back to the stock g35x specs?
https://g35driver.com/forums/attachm...5&d=1148444876
Also, do I need 2 wheel alignment or 4 wheel alignment?
Thanks !!!
Old Jun 21, 2006 | 08:59 PM
Foo_G's Avatar
Yes have them use the AWD spec. The might not be able to get dead on and make sure they give you a print out of what you did align to this way you can decide on whether or not to get a camber kit.
Old Jun 21, 2006 | 09:22 PM
vrsc's Avatar
4 wheel alignment!!!
Old Jun 21, 2006 | 09:46 PM
  #30
Oggie's Avatar
Originally Posted by Foo_G
from the book
Foo, do you have the alignment specs for 05 AWD?
