07 G35 sport limited slip
Old Sep 29, 2006 | 11:12 AM
TTA's Avatar
TTA
I assume the new G35 sport will have the identical limited slip as before
My 03 sedan has an open diff which is a dissappointment with trac control off
Does the limited slip ever help with trac control on? I would think wheel slip would be controlled electronically first.
With traction control off, how long does it take the spinning wheel to transfer to the other side?
Old Sep 29, 2006 | 11:25 AM
jerminator's Avatar
I'm no expert, but I'd say the LSD would help in both cases. Without traction controll, the benefits are obvious, but even with traction control, I'd say the LSD will still help get equal power to both wheels and the traction control will be less likely to kick in or at least kick in much less.
Old Sep 29, 2006 | 12:46 PM
ElixXxeR's Avatar
You don't want the TCS to be acting as an LSD, it's a very artificial form of slip control. It's great for foul weather conditions, but not so great on a track, it's just going to eat up brakes and not be as quick. Unfortunately, Infiniti's LSD is a viscous type. A Torsen or similar system would be better because they have the ability to limit slip before it ever occurs.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
wojowojo16
Jul 27, 2015 09:57 AM
laksjd84
Jul 24, 2015 05:12 PM
nascarbuff17
Jul 16, 2015 10:23 AM
