Darn clock can't tell time
Old Nov 3, 2006 | 05:25 AM
nFiniti's Avatar
I have the nav package, when day light savings time kicked in last weekend my digital clock, the one on screen, stayed put. So now it is an hour behind and I can't figure out how to set it back. Manual says that this clock is set automatically by the GPS system. Anyone else have this problem?
Old Nov 3, 2006 | 06:36 AM
G35-2-B's Avatar
Per the Nov 1st nav owners manual posted on line ( the one specific for the 2007 G35), it says this on page 8-10 under Clock Settings:
Select to toggle the daylight saving time setting between on and off. The
indicator light illuminates when the daylight saving time setting is set to
on.
Ref: http://www.nissantechinfo.com/infini...w.asp?mscssid=
Old Nov 3, 2006 | 07:22 AM
nFiniti's Avatar
Thanks G35-2-B but tried that already but still no joy.
Old Nov 3, 2006 | 07:32 AM
RBull's Avatar
Rated M
Is there an adjustment to select your time zone? Not sure that would have anything to do with it but might be worth a look to make sure compass/nav etc is in sync.
Old Nov 3, 2006 | 09:44 AM
Msedanman's Avatar
O.F. Administrator
Go into Settings......and select Clock ..
Don't know why it doesn't reset to EST from DST and back again. It should.
Perhaps the dealer can shed some light on it for you.
C.
Old Nov 3, 2006 | 10:17 AM
gspotter's Avatar
C.
You would think that since the nav knows where you're located, it would adjust accordingly. Some states are in more than one time zone.
Old Nov 3, 2006 | 10:31 AM
Pac-Man's Avatar
Just leave it alone for few months, it will correct itself.
Old Nov 3, 2006 | 11:34 AM
BlackGSedaN1027's Avatar
Yes there is an adjustment for the time zone that youre in. You need to go into the settings of the navigation. When I first got my car the settings were that of the West coast, and Im in the East coast. So I simply changed it and my time is correct.
Old Nov 3, 2006 | 01:32 PM
BigRed's Avatar
I just turned off the DST adjustment and the clock reset itself to the correct time. Not sure what the problem is, but I am sure the clock will be okay next Spring.
Old Nov 3, 2006 | 04:34 PM
chuckg35's Avatar
my car thought it was in california. after a brief discussion with the nav we agreed i was in DC and we have been friends ever since
Old Nov 3, 2006 | 05:12 PM
Msedanman's Avatar
O.F. Administrator
Exactly.....If he's selected 'adjust automatically to DST or Standard Time' and it's not adjusting, then there must be something wrong...
Dealer time.
C.
Old Nov 4, 2006 | 04:35 PM
nFiniti's Avatar
I deselected 'adjust automatically to DST or Standard Time' and it's now working. Kind of backwards but makes sense since the GPS should adjust this anyway.
Old Nov 4, 2006 | 06:51 PM
RBull's Avatar
Rated M
Good job. Glad it's working for you and no glitches on the car so far.
Old Nov 4, 2006 | 08:50 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Ahhhh yes that does make sense..... kind of
arora_g35
Apr 16, 2026 02:52 PM
EnCr1pt3d
Jul 8, 2019 02:48 PM
underworld
Aug 6, 2015 01:36 PM
