braking: sport vs non-sport
Old 05-11-2007 | 05:54 PM
G35Now!'s Avatar
Moderation-free
Originally Posted by Altersys
no.
do the rotors touch the ground? do the pads? what touches the ground? what is the real point of friction with the ground?
another way to look at it. are the "inferior" non-sport brakes incapable of locking up because they are so weak? that must be why only the sport cars have ABS.
Ah - excellent point. I hadn't thought it through all the way to each design being capable of reaching the adhesion limit of the tire. Fair enough
Old 05-11-2007 | 06:07 PM
d12a60n's Avatar
no.
Exactly - The function of bigger brake pads/rotors is purely for heat dissipation. They don't necessarily stop you faster in shorter distances. Stopping power (on the braking mechanism itself) is determined purely by the coeff of friction of the brake pads being used and F (force) of the clamps being applied. This of course doesn't take into account is the tires as Altersys has mentioned - which is the bigger factor in stopping. Bigger brake pads/rotors apply the same pressure - only over a larger surface area, so the only thing that changes is heat dissipation.
Old 05-11-2007 | 06:23 PM
Altersys's Avatar
yep. that, and with the same master cylinder (and caliper design) it requires less effort at the pedal due to the greater mechanical advantage of a longer moment arm (due to bigger rotors).
personally i did NOT like that about the sport. i like having to apply a little more brake pressure at the pedal because i find it easier to modulate at the limit.
Old 05-11-2007 | 07:55 PM
Altersys's Avatar
my acuras warped rotors to no end...... well, really only the TSX.... but it happened a few times and to my family's cars too (that were also TSX's)
here's to hoping for better metallurgical quality with nissan!
Old 05-12-2007 | 12:21 AM
Skaterbasist's Avatar
Retired SuperMod
Originally Posted by psteng19
It's not just about distance. Bigger brakes dissipate heat better so it will experience less fading for repeated stops.
Originally Posted by Sedanman07
True but usually fading only shows when racing and not day to day driving unless of course you are racing somebody on your way to work.
Many good points
I have to agree that larger rotors, assuming the numer of pistons in the calipers, and everything else being constant, the larger breaks will perform better at the track. Larger rotors, more area for heat to dissipate.
But as for daily use, I highly doubt there's any difference, except that the 13" rotors look better
Old 05-12-2007 | 10:20 PM
d12a60n's Avatar
Yes - they sure do!
Old 05-15-2007 | 09:13 AM
opus's Avatar
Thanks for all your inputs. I'll be putting cross drilled rotors next time I change any of my car's rotors. Purely for looks reason.
Old 05-15-2007 | 09:22 AM
Altersys's Avatar
hahaha. go with slotted, they are more reliable
i have opinions about everything
Old 05-15-2007 | 09:24 AM
UltimateGee27's Avatar
Originally Posted by andy2
I know people who had Inifiniti and Nissan but none complaints about brake warp.
On the other hand, my previous Accord had front brake warp that vibrates everytime I steped on the brake.
This is true. i have owned 3 Nissan vehicles and all have had brake noises early. Also most of my friends who had Nissan's experienced the same problems. I already have some squeaks on my G and i have less than 10k on it
Old 05-15-2007 | 09:25 AM
Altersys's Avatar
ummm... i think andy was saying the opposite of you, ultimate
Old 05-15-2007 | 09:30 AM
haha i quoted the wrong person my bad
Old 05-15-2007 | 09:37 AM
Altersys's Avatar
hehe. it's too early to be posting
Old 05-15-2007 | 01:00 PM
Infamous425's Avatar
i just re-read the brochure and it says sport models get redesigned calipers and larger brake discs for improved stopping power.
though it doesnt say whether improved over the non sport or improved over the 1st gen
Old 05-15-2007 | 01:07 PM
Altersys's Avatar
smart man!
i hate marketers..... spin **** whatever way they want, using the layperson's laziness against her/him. i guess it's what we deserve for being lazy, though... no?
as i keep saying, the sport brakes look cool, and seem cool on paper but are unnecessary in terms of fade resistance on the street, and since they don't improve stopping distance, are really just an aesthetic mod. i don't even think they feel as good, so there's nothing there either.
  #30
Old 05-15-2007 | 02:38 PM
turbo_gg's Avatar
no.
Are you saying that only the G35S has ABS?? I was under the impressions that all G35 models have ABS.
Quick Reply: braking: sport vs non-sport
