The holy grail - Complete Ipod integration
#46
Ok let me see if I can answer some of these.
The price is 220 for vehicles without sat, and 250 for ones with sat.
The cable comes from the Adapter, so it will come out of the bottom of the dash, and will have enough length to make it to the center console.
Installation takes about 1 1/2 hours, only because the radio has to come out, after that it is plug and play.
I do not know anything about the digital audio link, I am sorry, that question would be ansered by an Infiniti Dealer.
Ok, now the numbered questions:
1: Yes it displays info even when driving.
2: Controls work like so: Push Cat Folder to get to desired area (playlist, artisit, song, genre) push Seek, use the tuning **** or Cat folder button to scroll through the songs/artists,etc... press seek to select the desired song/artist.
You push the RADIO button the desired number times for audio inputs (1 push = FM 2 Push = FM2 3 Push is AM 4 Push = SAT/Ipod) or if you have a SAT Button you simply push it.
3. Aux Input if equipped will work as normal.
4. You can use the steering wheel to control volume, and on the early years the channel button will switch to next song, but on the newer years, the channel button will enter scroll mode, so it is useless.
5. Yes you can switch to Nav Display, or Ipod display with a simple push of the display button.
6. The Ipod runs through factory radio, so Yes it will DIM the sound and overide the speakers with directions.
7. Office is in Erial (Building only) Actual Shop is in Turnersville.
8. Ipod can be installed anywhere, Glove compartment, center console, in an Ipod Holder on the dash, ETC....
9. No Probelms with violating any warranties, it is a NIssan product, the Cabnles are Genuine Nissan too, we have just modified them to work with the front harness.
We are currently selling modules to Infiniti dealers.
I will work on some pics for you guys...
Brian
Brian
#47
#48
Brian
Brian
#49
Brian
Brian
thanks!
#50
Originally Posted by G35er_in_TO
If you have XM Sat service, does this harness/cable disable or override your XM sat service, or can you still have both?
#51
Originally Posted by shoeless
No, but I just stumbled accross this
http://www.autosound2000.com/ipodadapters.htm
I've confirmed with the manufacturer that it displays menus and album art through the video connection, so I just need someone to hack the new G's video protection thingy so we can see the screen while the car is moving.
#52
Brian
Brian
Thanks.
#53
Originally Posted by mbhforum
Did anyone buy this? It looks like there is a power requirement, so how would this work in the G35?
#54
Brian
Brian
#55
I bought this and installed this weekend. I am writing up me experience with it. It is a very clean install but does require access to the trunk, removal of the rear seat, carpet and partial dis-assembly of the rear console. The entire device is powered off the Sat Cable (Much the same way that no additional power is required for Sat). It took me a bit to figure out the controls (Steering wheel controls don't work as noted above) but over all very clean install and excellent sound.
I will have a further write up with photos later this week.
#57
#58
#59
It LOOKS like it uses a mini USB port for the power cable (standard plug), so by my reckoning, you could use a cigarette USB-ready charger to run it. Barring that, they have dc to ac converters that cost about 25 bucks.
#60
Thanks. Anybody have this? What are the dimensions? I wonder if this will fit in the center console of the G35. IS the remote IR or RF?
I think the dock you are looking at is smaller than the dLo and should fit in the cubby, but I'd e-mail the company and get the dimensions first. They were pretty quick to respond to my questions.
Here are the links:
http://forums.freshalloy.com/showthread.php?t=157557
http://www.glowview.com/cardock/
