speedooo with 20s
Old Feb 5, 2007 | 03:19 PM
marcelkatz's Avatar
speedooo with 20s
how will my speedo be affected by 20 inch wheels? if im going 30 will it say im going faster or slower?
Old Feb 5, 2007 | 03:22 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
depends on your tire size, here's the tire calculator i use:
http://www.discounttire.com/dtcs/infoTireMath.dos
type in the stock tire size and then the size you have now and it'll tell you how fast your going at whatever speed you select
-GP-
Old Feb 5, 2007 | 03:32 PM
ttrank's Avatar
Grocery getter
My stock size are only 0.6% off from my 245/35/20 and ~1% off from my 275/30/20's so if the 07's tires are near the old sport tire diameter you will be fine.
Old Feb 5, 2007 | 04:16 PM
GEE35FX's Avatar
Marcel if you are replacing your stock 245/45R18 tires with 275/30R20 tires then your speedo will read .7% too fast, which means when your speedo reads 60MPH you will actually be doing 59.6 mph. As Tim says, you will be fine .
Old Feb 5, 2007 | 04:45 PM
G35S's Avatar
http://www.rims-n-tires.com/rt_specs.jsp
Check out this calculator link in the title box. It should help you out...
Old Feb 23, 2007 | 07:49 PM
vansterdam's Avatar
Here's another good tire calculator.
Old Feb 23, 2007 | 08:30 PM
Deezflip's Avatar
I'm sure it doesn't matter to some people but i just thought i'd point out that the two tire calculators posted has difference measurements/results on a same tire size. Even after I chose both calculators to give me the results in Inches. I was using 275/30/20 in comparison to the stocks 245/45/18.
Old Feb 23, 2007 | 08:39 PM
Deezflip's Avatar
Ok, i tried another tire calculator site, and 1010tires.com's calculator is off compared to the other two.
Old Feb 23, 2007 | 08:41 PM
CalsonicVQ's Avatar
How do you calculate the accuracy of the speedometer when our front and rear oem 18" tires are of different diameters? I mean, what would happen if you go smaller/larger on only either the front/rear? What if you go smaller on the front and larger on the rear and vice versa?
Old Feb 23, 2007 | 08:47 PM
Deezflip's Avatar
I'm thinking the speedometer is reading the rear wheels on a coupe since that's the drive wheels. so making the overall diameter in the front and keeping the rear as stock size would still give you an accurate reading on the speedometer
Old Feb 23, 2007 | 08:49 PM
Deezflip's Avatar
crap...i left a word out.... making the over diameter in the front "smaller"...
maximino
Aug 12, 2015 02:05 AM
Soumilg
Jul 23, 2015 09:26 AM
Silverbolt
Jul 1, 2005 01:54 PM
ryno
Feb 4, 2005 12:06 AM
6mtpnut
Dec 6, 2004 11:55 PM
