Aluminum Pedals
Old Feb 23, 2007 | 05:09 PM
Christian's Avatar
Aluminum Pedals
Can I buy the aluminum pedals that come as part of the sport package for my X? I hate the look of the dirty rubber ones I have now. Would they just be pedal covers or a full replacement? TIA.
Old Feb 23, 2007 | 05:53 PM
Garnet Canuck's Avatar
Traveling Administrator
Places like Grubbs and EverythingG35 sells the aluminum pedal kit, but I'm honestly not sure if they will fit the 07s. You could call Grubbs and find out though. AFAIK, they are just covers that fit over the existing pedals.
http://www.grubbsperformance.com/Mer...G35SedanPedals
Old Feb 23, 2007 | 06:28 PM
Christian's Avatar
Are the stock ones in the sport package a cover?
Old Feb 23, 2007 | 06:37 PM
I just went out and checked Christian and it looks as though they are just aluminum covers.
Old Feb 23, 2007 | 06:40 PM
Christian's Avatar
Thanks Shane, maybe I can just order the same ones from the stealership.
Old Feb 23, 2007 | 06:42 PM
Yep, I would just double-check to make sure the 07s have the same size pedals.
Old Feb 24, 2007 | 08:42 AM
SPEEED's Avatar
Bad Toro
I'm sure you can call your dealer's parts department and order them by part number. I'm don't know if there is a difference in the physical look of the pedals between the sports vs. non-sport models (other than the aluminum trim itself), but if there isn't, your local parts department should be able to order a set for you.
Old Feb 24, 2007 | 09:01 AM
oneformula's Avatar
you could trade your car in for one with aluminum pedals... right?
Old Feb 24, 2007 | 11:27 AM
Cyanide Ride's Avatar
Uh, No?.
So these new pedals factory or aftermarket, would probably have to be screwed into place?.
If you look at the way the accelerator pivots, as it pivots, there is a smaller shape where it sits on top of (ok, that was a terrible explanation, just go look at the pedal) if the Aluminum pedals are "wrap-araound" style, they will interfere with the pedals normal function.
The brake pedal I can see there being no problems with a wrap around style clamp.
alessandro
Oct 8, 2015 09:29 AM
AL8782
Oct 3, 2015 10:26 AM
blnewt
Sep 25, 2015 01:48 PM
Blindside360
Sep 18, 2015 09:00 PM
