Jack Point question
Old Apr 8, 2007 | 12:44 AM
edpark30's Avatar
Jack Point question
I just changed my oil for my car ('07 G35x), and I used a hydralic jack to lift my car at the jack point. When I was jacking it up, the jack point metal bent towards one side. I was wondering that that is normal?
I hope i did not damage my car.
any responses would be thankful. Thanks.
Old Apr 8, 2007 | 12:50 AM
RichardxG35's Avatar
is not normal your jack point is bent
Old Apr 8, 2007 | 12:55 AM
edpark30's Avatar
another thought
It seemed to me that the jack point was going to bend regardless due to the heaviness of the car. I mean the manual says to put the jack on the jack point. Am I miss reading it?
Old Apr 8, 2007 | 12:59 AM
koyoki's Avatar
no... you didnt read it wrong.. that jack point is for the stock jack so it will bend if you use an aftermarket jack.
Old Apr 8, 2007 | 01:03 AM
edpark30's Avatar
comment
If the metal line, or the thing frame with the teeth on it bends a little bit? Does it affect the frame of the vehicle? I made sure that the aftermarket jack did not touch the body of the car, and it seems that the jack point is the vicinity of where to jack your car. Am I right on that? Will the frame be damaged due to the aftermarket jack?
Old Apr 8, 2007 | 01:08 AM
terrycs's Avatar
Hard to tell for sure unless you post a few pics, but you're probably OK. Unibodies are not that fragile.
Old Apr 8, 2007 | 01:40 AM
G-Whizzer's Avatar
Bending the frame with a jack if it's used in the right spot is pretty difficult.
These unibody frames are quite rigid - and with the extra welds on the 07, I'd be very surprised if you caused any damage....
Old Apr 8, 2007 | 12:36 PM
bkrider's Avatar
I was also concerned about bending the metal at the factory jack points. So I took a hockey puck and made a 1/8" wide by 5/16" deep groove across its diameter. When I jack the car I place the puck on the jack pad so that the metal lip of the jack point drops into the groove. So far, no bending problems.
Old Apr 8, 2007 | 01:09 PM
PRMax's Avatar
Was wondering what to use as a pad on the two metal points on my jack stands since I am due to rotate my tires. Will have to try the hockey puck idea.
Old Apr 8, 2007 | 01:58 PM
edpark30's Avatar
comment
will the hockey puck idea work? Actually I was driving the car today, and I don't know if i'm paranoid or not but it seemed like the car was a bit off center. as in it would drift to one side oh so slightly, maybe it is a tilted road, but maybe i'm paranoid. Don't know but I hope there is no damage done.
How would one fix a problem if I did end up bending the frame?
Old Apr 8, 2007 | 02:10 PM
PistolPete13's Avatar
Hey Ed,
Take a picture of the area if you can, I seriously doubt you damaged anything. I've managed to bend frames, but that was with hitting a guardrail @ 30MPH!
Instead of a hockey puck, I've been using this:
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
It's more expensive, but it is well made and stable.
-Pete
Old Apr 8, 2007 | 03:25 PM
koyoki's Avatar
You are paranoid. IF the car frame would bend just because you jack your car than if you have a flat next time dont jack your car even with a stock jack bcos it would bend the body.. To bend the frame of a car you need to, drive 40 mph and hit a wall.
Old Apr 8, 2007 | 05:06 PM
jameyb's Avatar
The hockey puck idea works great. That is what I use to jack up my car.
Just one thing to clear up - Did you just bend the lip at the jackpoint? If so, your car will be fine, it will just have a small scar. As someone else suggested, take a pic and post it up.
Old Apr 8, 2007 | 08:00 PM
edpark30's Avatar
reply
I think i did bend the lip only, hopefully, I will take a picture and post it. Thanks guys.
Old Apr 8, 2007 | 11:42 PM
CarNutz's Avatar
The end of the stock jack has a groove that goes around the guide on the jack point. You just bent the guide for the emergency jack. You should have another jack point in the general area of the emergency jack point. Use that next time with your garage jack.
