G35x sudden down shifting causing extreme jerking motion
Old Apr 19, 2007 | 05:07 PM
tromyj's Avatar
Shortly after reaching the 2500 mile mark, my 2007 G35x started down shifting from 2nd to 1st rather abruptly and causing some major jerking. I noticed it most when slowing down and my speed is at or near 7-5 miles per hr. Has anyone else noticed this?
Old Apr 19, 2007 | 05:25 PM
max2k1's Avatar
Originally Posted by tromyj
Shortly after reaching the 2500 mile mark, my 2007 G35x started down shifting from 2nd to 1st rather abruptly and causing some major jerking. I noticed it most when slowing down and my speed is at or near 15 miles per hr. Has anyone else noticed this?
Very odd .... why would the tranny downshift to first at 15 mph ??
Its too fast !!!
If it all downshifts to 1, it should be at something like 5 mph or lower
If you can reproduce it easily, just take it to the dealer ..... its probably harming the drivetrain with that abrupt downshifts.
Altersys's Avatar
is your shifter in sports mode?
Old Apr 19, 2007 | 05:31 PM
tromyj's Avatar
I just checked again and it happens between7-5 miles hr.
I'm running D mode.
Old Apr 19, 2007 | 05:36 PM
Altersys's Avatar
that's pretty slow. my car downshifts early too. it might be more pronounced on the AWD version since the front tires will "dig in" and cause the body to pitch forward.
Old Apr 19, 2007 | 05:54 PM
G35Now!'s Avatar
Moderation-free
Don't think so - thought I read that the X will only send power to the front wheels if it finds wheel slip in the rear? You'd think that means no direct connection, and thus bite, on the front wheels at this speed?
I have not noticed this as a concern on my S, although when the car downshifts to 1st it is noticeable (partly because the brakes are already on, and this adds braking force).
Old Apr 19, 2007 | 06:02 PM
03FXer's Avatar
Yes I have also experienced this. However, it does not happen on all second to first downshifts. I have also noticed that the rev matching does not work as well when going into second from third or into first from second (it is not a smooth as the other downshifts). From fifth to fourth or fourth to third it works like a charm.
Old Apr 19, 2007 | 08:05 PM
Altersys's Avatar
good point. not sure how the front drive wheels work under braking forces vs acceleration forces. There could be a difference.
Old Apr 19, 2007 | 10:13 PM
AesonVirus's Avatar
I have an X, and mine drops to first only coming to a complete stop, or very close to it, like 1-2 mph.
No jerking
Old Apr 20, 2007 | 08:16 AM
Tiger's Avatar
Mine will downshift early on aggressive braking, but on light braking, the downshift is hardly noticable.
At first I didn't like how newer cars downshift when braking, but now that I am used to it, I kindof like it.
Old Apr 20, 2007 | 01:11 PM
tromyj's Avatar
I was thinking it had something to do with the type of gas I'm using (BP Ultimate - 90+ octane). I've seen other threads related to the type of fuel to use, but none reference this possible side effect.
Jiggerjuice
Oct 5, 2015 02:33 PM
Blakearold
Aug 19, 2015 10:20 AM
ClwMike
Jul 23, 2015 12:55 PM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
