View Poll Results: Which of the 3 available modes do you use the most?
D (Drive)
66.35%
DS (Drive Sport)
13.46%
Manual Shift
20.19%
Voters: 104. You may not vote on this poll
Auto Mode
Old May 9, 2007 | 02:13 PM
spacecowboy's Avatar
Originally Posted by JMZ_blkobsidian
For the first 4 months, I used D almost exclusively and never really got hooked on the paddle shifters the few times I tried them.
Recently, however, I've been shifting manually with the center shifter almost 100% of the time. I really, really like that feature and (to me) feels much smoother and fluid than using the paddles.
I got scared off of DS mode when (below 1k miles) the G would really hang onto 2nd gear when accelerating out of a low speed turn. The handful of times I exceeded the 4k rpm boundary was in this manner.
Going into a turn fast and braking in Speed mode will often cause a downshift, and it hangs because the higher RPM in a lower gear will launch the car when you step back on the gas. If you don't accelerate hard (i'm assuming you came into the turn with some speed) the trans hangs, due to the downshift rev matching. It supposedly cuts back on emissions.
Old May 9, 2007 | 02:17 PM
douglas555's Avatar
Okay, this might be a dumb question, but what's the difference in DS and manual mode?
Old May 9, 2007 | 02:23 PM
G-Whizzer's Avatar
DS = Damn Skippy!! er... "D"rive "S"port mode.
A quick search here brings up the whole write-up.
DS will shift a little more aggressively and hold higher RPMs and lower gears longer. It's a blast.
Manual requires you to manually shift.
DS mode is engaged when you pull the shifter left and leave it centered.
Old May 9, 2007 | 02:24 PM
DS is still auto, you don't do the shifting. M is manual tiptronic, you have to do every upshift (but not the downshifts, which is freakin sweet!)
Old May 9, 2007 | 02:38 PM
timn99's Avatar
Downshifting is optional, if you want engine braking.
Old May 9, 2007 | 02:39 PM
douglas555's Avatar
Thanks. Obviously I don't use DS too much. I'm more of a D kind of guy.
Old May 9, 2007 | 02:42 PM
G-Whizzer's Avatar
douglas..... join the dark side..... LOL.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Charchar66
Dec 19, 2019 01:17 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
master111
Sep 25, 2015 08:32 PM
