G35x burnout
Old Jun 13, 2007 | 12:36 AM
DrifticuS's Avatar
Thumbs up G35x burnout
Is it possible to burnout in the G35x with VDC off. I didn't think so but I searched and found a post somewhere that said you could. Thanks...
Old Jun 13, 2007 | 01:34 AM
hyukki's Avatar
Uh... Maybe a little bit of wheelspin.... but if you think about it... theres no way you can do burnouts unless your car is strapped to something.
Old Jun 13, 2007 | 02:18 AM
DrifticuS's Avatar
Yes, but isn't the car RWD until you lose control, then AWD, but if VDC is off, then you don't lose control..so RWD all the time?
Old Jun 13, 2007 | 02:40 AM
hyukki's Avatar
I thought the car was AWD when you take off for extra grip whether or not if you lose control... I think it only switches to RWD if you're going over a certain speed.
Old Jun 13, 2007 | 08:43 AM
Karnidge's Avatar
Yes. It is AWD up to 30mph for grip, then switches to RWD.
Old Jun 13, 2007 | 08:47 AM
kmuniz78's Avatar
simple solution, just try it!
Old Jun 13, 2007 | 08:53 AM
spacecowboy's Avatar
been there, tried it, and no good! i even tried in the rain and couldn't get even a little spin.
o, and forget about trying to do a donut
Old Jun 13, 2007 | 09:15 AM
Syclone43's Avatar
Not likely
Without a lot more power, I would say the answer is no. I used to own a Typhoon, another AWD vehicle, you couldn't do a burnout without making a LOT of power. Even 400hp wasn't enough, although there was an awesome video of an 800 hp Syclone doing one.
Old Jun 13, 2007 | 09:54 AM
DrifticuS's Avatar
k guys, thanks for the replies. I would think donuts in the rain would be plausible...but I think I'll just wait till it snows...
Old Jun 13, 2007 | 09:57 AM
Neal376's Avatar
there is an AWD fuse for the 05 models that you can pull to disable the front wheels. try searching for it in your 07
Old Jun 13, 2007 | 10:14 AM
yeah, the fuse box tells you where it is in the 05, but not in the07. gotta check the manual though.
and trust me, you can't donut in the rain!
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
AJC128
Nov 1, 2015 11:55 AM
Claudiu
Sep 26, 2015 01:04 PM
