Auto transmission jerk or 'hiccup'
Old Dec 20, 2007 | 08:51 PM
  #46
exxlonghair's Avatar
sensitive throttle
I just took my G35x sedan in for its first servicing and after reading all the posts here decided to have them flash the ecu. I basicaly just lied and said I was having some troubles with my cruise control (ive never even used it), then I told them I'd done some research and found a TSB relating to it and the fix was to flash the ECU. The guy looked at me surprised at first (I was wearing a misfits shirt when I went in to the dealer) then was like "no problem, we've done a couple of those recently. They also took care of the key issue.
When I got back in my car the next morning, it was like night and day. The car drives so goddamn smooth now, taking off from a stoplight is a thousand times better and none of the power is gone. I'm glad I found this board and took the advice of the people. Now if I could just get a backup camera my car would be perfect. I shoulda got the tech package.
Old Dec 21, 2007 | 11:32 PM
  #47
silverG2007's Avatar
Glad to hear it!
Old Dec 24, 2007 | 06:41 AM
  #48
Vitorio's Avatar
Originally Posted by KJC5050
I think this is different from what the OP is describing. Several people have commented on the harsh shift/bang into 3rd at WOT... when shifting with the paddles or auto stick. It's apparently just a quirk of this auto transmission, and was present in the last generation. There's a separate thread on the topic.
Thats excatly what happens when I shift with the paddles! although it feels powerfull with high RPM shifting, but I afread its a problem and it might get worse. I've been trying to read the topics but i didnt find an quick answer to this...is it a normal thing in the G or do I need to check the dealer and fix it as a problem?
thanks
Old Dec 24, 2007 | 09:47 AM
  #49
Da-G-SpoT's Avatar
I have a similar problem with my G. No matter how hard im driving or how slow i am going there is always a jerk at 3rd gear while in MM mode. I leave it in D and i never have an issue. A problem i have seen lately, apart from the 3rd gear jerk, is the hiccup? While in gears 3, 4 or 5 while engaged already or "locked in" if i floor it i get this slip feel. Its more like a quick gear change, even though i havent shifted, then the car is off. It is more like being in 3rd, 4th or 5th gear at around 2500 - 3000 rpms and then flooring it. I get acceleration for about 500 rpms then a stutter then im gone. Again this happens in the higher gears not the lower set ( 1, 2 ) . Is this the same thing you guys are talking about? If so, what can i tell the dealer? Unless this is considered "nomarl". Again this is only in MM mode, i never have any problem in Drive.
Old Aug 1, 2016 | 12:02 PM
  #50
cdbrown1989's Avatar
how much was to flash the ECU????
Old Aug 1, 2016 | 12:51 PM
  #51
vqsmile's Avatar
Did you happen to notice the time stamp? 12-20-2007, 05:51 PM
Dallsinghjr1
Sep 17, 2023 11:25 AM
Charchar66
Dec 19, 2019 01:17 PM
g.spot
May 9, 2016 10:54 PM
f22raptor
Mar 18, 2016 08:50 AM
dcsbh1
Oct 1, 2015 03:15 PM
