Windshield fog
Old Oct 18, 2007 | 12:13 AM
JayJay's Avatar
Windshield fog
I have noticed that my windshield tends to fog up often. When i put the defroster on it clears up for a while and then fogs right back up. Does anyone else have this problem or know the possible cause of this. Thanks!
Old Oct 18, 2007 | 02:48 AM
hyukki's Avatar
Temperature differences + moisture?
Old Oct 18, 2007 | 04:26 AM
d12a60n's Avatar
Use colder air than the outside or some Rain X anti-fog wipes
Old Oct 18, 2007 | 10:10 AM
Lemodular's Avatar
stop breathing
Old Oct 18, 2007 | 11:25 AM
Christian's Avatar
Do you frequently use recirculate?
Old Oct 18, 2007 | 11:40 AM
Cyanide Ride's Avatar
In addition to trying the useful suggestions mentioned, try cleaning the inside of the windshield. If you run your finger down on a spot of your windshield and make a clean spot, you need to clean it.
In hot or hotter climates some of the fumes coming off the plastic settles on the windshield and forms a film. This film increases your chances of the window fogging up. Might be worth a shot.
Old Oct 19, 2007 | 03:51 AM
CoppellStereo's Avatar
mine does it too even when its like 100 degrees outside, its just slightly at the bottom though, i'm guessing where the defog vents are. maybe you have some sort of oil on your glass
Old Oct 19, 2007 | 09:18 AM
MikeyC's Avatar
This is a great suggestion. The dirt particles on the windshield give moisture something easy to cling to and this facilitates the formation of fog.
I don't know what it is about Infinitis but the windows get dirty REAL fast. I clean the front windshield of my G35x and later that day it's already getting dirty again. My mother and some other people I know have M's and they have the same complaint.
Old Oct 19, 2007 | 05:55 PM
logik05se's Avatar
if its just happening at the bottom of your windshield and its on the OUTSIDE OF THE GLASS, its because when you run your ac and have recirculate off, 15% of the air still comes out of the defroster vents. When its warmer out then the temp you have your car blowing out, the cold air keeps hitting the windshield and causes condensation. If its in the inside of the glass thats something completly different then.
Dallsinghjr1
Sep 17, 2023 11:25 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
G35xdriver04
Nov 7, 2015 08:31 PM
NailBomb
Oct 28, 2015 07:53 AM
