Trunk opening after closing it.
Old Nov 8, 2007 | 01:11 PM
SOUPG35s's Avatar
Has anyone run into this problem? Everytime I close the trunk lid the car would beep and the trunk would open again. I would have to slam it shut several times before it would close shut. I brought it the dealer to get it fixed but I guess they didn't solve the problem.
Old Nov 8, 2007 | 01:23 PM
shawnost's Avatar
Do you have a key in the trunk?
Old Nov 8, 2007 | 01:45 PM
Christian's Avatar
Are you holding the key close to the trunk release button? The manual says that if you have the key too close to the car it will have trouble determining whether the key is inside or outside of the car.
Old Nov 8, 2007 | 02:29 PM
brittonv's Avatar
I noticed that if I close the trunk from one of the edges it would do that. If I put my hand in the center near the button and close it the problem went away.
Old Nov 8, 2007 | 02:34 PM
kring's Avatar
It does this is the key is in the trunk, or like others said, it's so close to the trunk that it thinks it may be inside...
It annoyed me once... then I realized my key was inside... and I thanked her for notifying me of my stupidity with a fresh coat of wax
RANC3R's Avatar
I have the a similar problem!! my trunk only closes if you close it a certain way, but when i start moving it opens by itself... nobody knows what the prob is and it gets to me!
Old Nov 8, 2007 | 02:38 PM
hyukki's Avatar
Oh jeez.
It reminds me of the time when I was freaking out over this.
Old Nov 8, 2007 | 02:58 PM
stanfna's Avatar
this exact thing happened to me this morning!
turns out i had left my key in my gym bag. I was very thankful Infinity thought this one through. being locked out of my car wearing shorts & a t-shirt with the temp. below 32 degrees would have SUCKED!!!!
Old Nov 8, 2007 | 03:27 PM
SVLRx's Avatar
dang, i didnt know this. Good thing i didn't leave my keys in my car. B/c last week i was thinking about when i go out to play ball, i would leave my keys in the car and then lock the door, and just click the button on the outside to get in later. Lucky i didn't actually do that, b/c then i would be locked out
Old Nov 8, 2007 | 03:29 PM
Christian's Avatar
^^ Actually the car would beep rapidly and the door would not lock.
Old Nov 8, 2007 | 03:40 PM
stanfna's Avatar
when i go cycling....i take the valet key with me and leave the remote in the center console. you can lock the door using the key while the remote is in the car (assuming you have not installed the keyhole delete )
Old Nov 8, 2007 | 08:03 PM
G-Whizzer's Avatar
Maybe the remote is screwy? The trunk release button might be stuck down?
Old Nov 8, 2007 | 10:23 PM
KulG35's Avatar
this happens to me if unless i stand DIRECTLY behind the truck release buttom
Old Nov 8, 2007 | 11:41 PM
ABQ_G35's Avatar
Wait, they told me there was no longer a "valet" key with the '07, wonder when they changed that.............
Old Nov 8, 2007 | 11:45 PM
Christian's Avatar
There isn't a valet key, just the metal door key. It's absolutely useless unless your battery dies.
