Windows auto-up not working
Old Nov 28, 2007 | 12:02 PM
gymcshoe's Avatar
Has anyone encountered this? I disconnected the negative battery terminal to install some bulbs and now the window's auto-up feature doesnt work. Auto-down works, and up works but not Auto-up. Does anyone know how this can be fixed? Thanks
Old Nov 28, 2007 | 12:04 PM
Christian's Avatar
You just have to reset the anti-pinch thing. Roll the window all the way down and hold the switch down for 5 seconds then roll the window up and hold the switch for 5 seconds.
Old Nov 28, 2007 | 12:08 PM
derek@grubbs's Avatar
PREMIUM SPONSOR
My master tech tells me you need to reprogram the switch, simply push button, making window go all the way up, hold there for ten seconds, try down same, should be redone! Any ?, call us or e-mail!,thx!
Derek(866)789-0207
www.grubbsperformance.com
Old Nov 28, 2007 | 02:32 PM
rocaveli's Avatar
who to believe, venerated Super Mod ChristianN or derek's mysterious Master Tech?
Old Nov 28, 2007 | 03:15 PM
AlterZgo's Avatar
Split the difference and hold the button for 7.5 seconds down/7.5 seconds up - no more, no lesss!
Old Nov 28, 2007 | 04:43 PM
Christian's Avatar
Maybe I'm wrong, but that's what I did and it worked.
Old Nov 28, 2007 | 05:22 PM
gymcshoe's Avatar
Thanks guys, I'll give it a try and will post results
Old Dec 2, 2007 | 02:37 AM
NG35S's Avatar
worked for me thanks guys
Old Dec 2, 2007 | 06:07 AM
Garnet Canuck's Avatar
Traveling Administrator
IIRC, the manual states 3 seconds........but who's counting?
Old Dec 10, 2007 | 05:40 PM
imminence's Avatar
Hey guys. I ran into this same issue with both of my driver's side windows. Auto down works but auto up doesn't. I did the reset for the rear window and it worked out fine. With the front, after I tried the reset, the window wouldn't work at all. I'd have to wait for about a minute before it'd work again, but the same problem persists; auto down works but auto up doesn't. I must have tried doing this reset about 10 times with no luck.
Anyone come across this issue?
Old Dec 10, 2007 | 05:47 PM
cnugs127's Avatar
That's a strange one. Good luck.
mike730
Jan 12, 2018 04:25 PM
Gip
Aug 24, 2015 05:31 PM
Jussaku
Interior
Jul 29, 2015 04:13 PM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
