Can't burnout
Old 08-11-2008, 04:19 PM
fecurtis's Avatar
Originally Posted by dmitriylm
Get some 20's with very little grip to do some burn outs? Right....because everyone changes their wheel/tire combination every time they decide to do a random burnout at a stoplight. Who needs grip anyway right? I mean all my other day to day driving consists primarily of burnouts anyway. The safety of increased tire grip is largely exaggerated right?
I believe he was being facetious. He basically said "if you want to do good burnouts, just spend about $5000!".
If he was serious, I have better advise, spend $1000 on a fox body Mustang. You can do burnouts all day long...in a closed course of course.
Old 08-11-2008, 04:38 PM
LiquidGx's Avatar
Get some N20 and put the largest jets in, hit the gas and then SQUEEZE!!!!!
Old 08-11-2008, 04:43 PM
Texasscout's Avatar
Received 2,116 Likes on 1,768 Posts
I just hate seeing people abuse good machinery. I drive the snot out of mine for one weekend a year (Raging Bull Texas Stampede), but I don't abuse it.
These things are not cheap to fix if you break them. As you will soon find out. So don't bitch to the service writer about "warranty".
Old 08-11-2008, 05:26 PM
mIKE's Avatar
Are you spinning only one tire and not knowning it?
Old 08-11-2008, 05:30 PM
ugaexploder's Avatar
burnouts in these cars are a bad idea...i tried to do it in the loaner and it went into "limp home" mode the 335i's were notorious for before the oil pan issue...this car wouldn't even shift into second gear because i tried to burnout...i had to shut the car off and let it "cool off" for about 10 minutes before I was able to use the other gears...even in drive, it would just stay in 1st gear and would not shift...i will never do a burnout or attempt one in this car again
Old 08-11-2008, 07:42 PM
snowcrossmxz's Avatar
exactly, if u wanna go fast, and for cheep, a stanga is the way to go.
the old 5.0 and 4.6. there is no replacement for displacement.
as for the G35 auto, ehh im not sure. i got the 6mt and my *** end slides all over the place
Old 10-07-2019, 02:32 PM
Yusef57's Avatar
G35 Coupe
taking off sensor
Originally Posted by Phalanx
I turn off the VDC but still can't do a burnout. Every time when the rear wheels started to spin, the tranny cut the power. Did anybody here have the same problem?
If anyone here successfully did some burnouts, please tell me what you have done.
Thanks
There is a sensor under the shift ****. U lift up the middle compartment then pull down the small bottom part of the know and take off the little clip and bring the **** up and it comes off after lift on the gray part of the middle. You will see that the whole middle will come up. There will be a sensor there( its a pretty big sensor) disconnect that and the VDC, Slip, and the ABS light will come on. After that u can KILL tires like crazy
Old 10-07-2019, 03:34 PM
Urbanengineer's Avatar
Received 1,031 Likes on 948 Posts
Thanks. I've been waiting 11 years to figure out how to do it.
Yusef57 (10-07-2019)
Old 10-07-2019, 07:26 PM
Triton3.5's Avatar
^^^lol
Old 06-28-2021, 02:34 AM
Dizzyzomby's Avatar
G35 Base AT
Hey not to steal the board but for some reason I don't have the power to even try to get a burnout started, I hold the brake and do the gas it only revs to just under 2k, and then it slowly starts to accelerate. I just cannot figure it out.
Old 06-28-2021, 01:10 PM
LoSt180's Avatar
See post #4 in this thread. The stock behavior is that if the the ECU sees brake and gas at the same time, it cuts power to the engine. It's a safety feature, thank those old "unintended acceleration" issues that happened in the early 2000s. The car needs to be modified if you want to do a standing burnout. The most low-tech option is to unplug the switch for your brake lights at the top of the brake pedal. Just remember to plug it back in before driving on public roads because your brake lights won't be working. Another option is a tune from Uprev with ARC features will allow burnout mode without having to disable your brake lights.
Old 06-30-2021, 09:16 AM
seymore4's Avatar
This is by far the best and safest way. PM me if you want to give it a try
My350
09-28-2005 09:54 PM
inspector_yoo
12-11-2004 03:59 PM
G35WANTED
10-12-2004 11:54 PM
blackinfiniti
08-05-2004 04:09 PM
ijk
11-15-2003 08:06 PM
Quick Reply: Can't burnout
