Service Engine Soon notice @ 1300 mi
Old Sep 3, 2008 | 12:08 PM
kpfury's Avatar
are you kidding me?? I haven't even been pushing the car hard (well maybe a little starting at like 800 miles or so) but still... could it be because the dealer put in crap oil/filter?
Old Sep 3, 2008 | 12:16 PM
G-Funk78's Avatar
This has happened to a few G owners in here. It's most likely the gas cap so just tighten the cap and wait awhile for the SES light to go off. If you don't want to wait, you can disconnect the positive lead on your battery for 10 minutes and then reconnect it after you've tightened the gas cap and the light should go off. If you try that and it doesn't, then take the car in.
Old Sep 3, 2008 | 01:36 PM
dohturdima's Avatar
+1 - it happened as soon as I took possession of the car, the cap was not ratcheted tight enough at the dealership. Gave me a scare, too - until I read this forum.
Old Nov 12, 2008 | 07:27 PM
malagabee's Avatar
just happened to my g35S with 1700 miles. checked out the cap was a bit lose but is it just me or these caps just don't feel like they are tightening at all eventhough a few clicks are heard. was giving me the P0455 code. I have a code scanner so can easily clear it. will find out if it goes away tomorrow. . it better!
Old Nov 13, 2008 | 02:14 PM
silverG2007's Avatar
Could be anything. I don't recommend unhooking the battery to "clear the code."
The code is there for a reason. Usually the local auto parts store can read/clear the codes for free anyways.
Find out what it is first.
Old Nov 13, 2008 | 03:19 PM
malagabee's Avatar
come to joysey and i'll scan your obdii, but if it's the P0455 code like i had lastnight, it'll be cleared by time you got here if you've tightened the gas cap
Old Nov 13, 2008 | 07:00 PM
red00lght's Avatar
I had it on mine. The only way I got it to go out was to go past the click noise with the gas cap and then go half-way to the next click. This seems to make it tight enough to put out the light. I'm going to write it up next time I bring the car in.
Old Nov 13, 2008 | 08:38 PM
kurob's Avatar
My Infiniti is fine but my '08 Pathfinder had this exact same problem. I used this method between oil changes and they swapped the cap out for a new one the next time I brought it in. I haven't had the problem on it since.
Old Nov 14, 2008 | 10:09 AM
fecurtis's Avatar
Oil and an oil filter won't set off an SES.
Just tighten your gas cap.
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Phenomenon9
Aug 9, 2015 01:34 AM
ghost_g35
Aug 7, 2015 10:31 AM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
