Can someone w/o much stuff in their HDD read this pls
Old Sep 20, 2008 | 05:36 PM
jdanielsg's Avatar
if you have nothing on your HDD except the NAv, little or no songs, can you check what the free space is...
something went wrong with my HDD I just want to check if its really cleared out or the files r just "hidding" somewhere.
Old Sep 20, 2008 | 06:09 PM
kool-aid's Avatar
i know mine wasn't 9.3gb
Old Sep 20, 2008 | 10:52 PM
kool_yaar's Avatar
the only way i know how to is by going through the music box options, but im guessing you dont want that so, ill see my way out ...
Old Sep 21, 2008 | 06:07 AM
jdanielsg's Avatar
i did that i am just comparing hence the reason for this post
Old Sep 21, 2008 | 11:09 AM
kool_yaar's Avatar
ok in that case when i first got my car and copied 1 cd that was about 9 songs, i checked and had about 8.5'ish
Old Sep 22, 2008 | 11:05 AM
GTScott's Avatar
Mine is empty as the car is brand new. If someone wants to tell me how to check, I am more than happy to check for you.
Old Sep 22, 2008 | 01:51 PM
jdanielsg's Avatar
hi that would be great when in music box, chosen with the aux button, it will say no audio file, u click menu on the screen should bring u to option or settings and you can view free space/used space there. Thanks
Old Sep 22, 2008 | 03:03 PM
GTScott's Avatar
I will print these instructions out and check tonight.
Old Sep 22, 2008 | 07:22 PM
GTScott's Avatar
I just went through your direction (perfect, BTW) and in the unused space on my never used, 2 day old 2008 it says 155:28. If there is something else I need to look up, let me know.
Old Sep 22, 2008 | 09:14 PM
jdanielsg's Avatar
thanks man i will go compare with mine.
Old Sep 22, 2008 | 09:41 PM
LOW2000's Avatar
Mine is also empty and is 155:28. The salesman in his initial walk-through loaded a CD onto the drive which I have since deleted via the "clear music box data" option.
KallDay86
Jan 8, 2016 12:42 AM
thechitoguy
Oct 1, 2015 05:25 PM
NyCrAzY
Oct 1, 2015 09:19 AM
Learned Hand
Oct 1, 2015 09:02 AM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
