Hood Rattle, normal??
Old Oct 30, 2008 | 02:09 PM
klab0001's Avatar
I was washing my new G35XS for the first time ... while washing the hood I noticed a rattle, if I pushed on the hood it would move almost like the hood latch needed to be adjusted. Hope this is not normal ...?
Old Oct 30, 2008 | 02:10 PM
hankookstyle's Avatar
not normal.
tight the bolts.
Old Oct 30, 2008 | 05:37 PM
LOW2000's Avatar
Back the rubber stops out on either side of the hood about 1 turn.
Old Oct 30, 2008 | 06:01 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
^ WHS... takes a little trial & error a couple of times to get it right.
Old Oct 30, 2008 | 06:36 PM
cdmorenot's Avatar
rattle or a squeak ? if its a squeak adjust the rubber stoppers if its a clunk try to mess with the latches see if you can duplicate the sound there are TWO latches. goodluck. let us know what it is..
Old Oct 30, 2008 | 08:53 PM
ParkStr8's Avatar
I have the same thing...going outside to check it now...
Just checked...unscrewed the rubber stoppers and now tight as a drum.
Thanks guys.
Old Nov 3, 2008 | 01:30 AM
rustyeleio's Avatar
Yup had the same problem. It was the rubber stoppers at the front corners of the hood.
Old Nov 3, 2008 | 09:38 AM
IvoryPearl07G's Avatar
lol i have helped 3 other g35 owners with that issue. you figure they would check that on the predelivery area checks at the factory?
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
hrdwirk1
Oct 2, 2015 06:34 PM
