which TPMS will work?
Old 01-31-2009, 02:02 AM
rustyeleio's Avatar
Originally Posted by bat6wc
so what you guys are saying is that buying sensors not only depends on the model year, but also what style wheel? I am putting on the OEM 19" Rays on a 08 G35xS Sedan. I was planning on purchasing sensors that look like the above ebay ones. would i be correct to do so?
You should buy the TPMS sensor based on your vehicle model and year. If you buy the wrong sensor, then it may not communicate with your Body Control Module.
The wheel brand/style will determine what extra parts (if any) you need to buy to fit the TPMS. If you use an Infiniti wheel then maybe it will work fine alone. If you have a 3 piece then you may need to purchase a 90 degree adapter or some other adapter. Best is to ask the shop you are getting the wheel from.
arora_g35
06-24-2020 01:58 PM
obender66
18 Inch
03-13-2016 12:20 PM
Big C
19 Inch
11
10-03-2015 05:11 AM
TheKnite
08-14-2015 07:59 PM
attarday
07-15-2015 04:03 PM
Quick Reply: which TPMS will work?
