Defence of the crankcase, NEW MOD :)
Old Jul 10, 2009 | 05:06 AM
harp00n's Avatar
I live in Ukraine, and we have a lot of "bad surprises" on the roads here that could damage the engine (rocks, junk...).
So I decided to install the defence for the crankcase (made of steel by our local ukrainian shop). The only issue, that bothers me - is the weigth of it - 10-12kg (22-26lb). On the other side, I beleive the defence will make some "underbrace strengthening" effect.
The only pictures I've got is for M35x, but I guess it'll help:
"BEFORE" ---------> "AFTER"
P.S. The alternative is the defence made of fibreglass, the weight is about 5 kg (11lb), though it won't help hitting huge rock and no "strengthening" effect.
Old Jul 10, 2009 | 02:58 PM
kregg's Avatar
Wow, that looks like a very nicely manufactured component. For the 15 extra pounds I'd go for the steel version, you are correct, it would last much longer as protection as described.
Old Jul 10, 2009 | 03:08 PM
james0076ss's Avatar
22-26 LB more is not bad, campared to if some garbage gets in your engine. Looks almost OEM
Old Jul 10, 2009 | 05:43 PM
earth0's Avatar
Wow! That look professional.Nice work!!!
Old Jul 10, 2009 | 08:12 PM
truzaro23's Avatar
how do you drop your oil now?
Old Jul 12, 2009 | 11:18 PM
mifesto's Avatar
this is custom? take note the patterns on the smaller shield after the front axle. now look at the patterns on this "custom" shield. this appears OEM because it probably is of a sort? maybe a nissan option only made in japan? i can only speculate but a shop would not bother adding slits to something simple as a custom underbody shield. maybe they took an OEM plastic dust shield and used as mold for a steel one.
Old Jul 13, 2009 | 12:42 AM
johnnyzee's Avatar
i want one for my winter coffee shop drive throughs and snow glaciers on the highway.
how much?
do they ship?
Old Jul 13, 2009 | 05:11 AM
harp00n's Avatar
how much?
do they ship?
Well, I can give you their contacts, but I don't know, if they would ship it to the USA
poligon@poligonavto.com
The defence is not OEM, but they supply almost every service-station in Ukraine with their production for every car we have here, so they are well-known and the quality is good.
P.S. But I decided to put a fibreglass protection, as it would weight 1.5 times less than steel one (and cost 1.5 more ).
Old Jul 13, 2009 | 04:03 PM
mifesto's Avatar
im not questioning the quality of it. i was just thinking it wasnt really a custom job as a shop wouldn't bother matching those little slits instead would make it out of flat steel shielding like how they make it for rally cars. this looks like they took an oem plastic piece and made a mold.
Old Jul 20, 2009 | 05:25 PM
harp00n's Avatar
OK, here's an update. This is OEM slim defence:
This one was hand-made (the inner side) of armored fibreglass:
and the outer side:
It is very solid, about 12mm thick, the weight is about 8kg.
Charchar66
Dec 19, 2019 01:17 PM
Video Share
Jan 31, 2017 04:00 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
RWDguy4238
Sep 30, 2015 12:13 AM
