Symptoms of a bad rim?
Old May 1, 2010 | 05:02 AM
muyrec's Avatar
when driving i noticed there would be a constant judder that would start to get noticeable at 25mph and above and it'll get worse when i go faster. Best way i can describe it is kinda like a "bouncing" motion. Up and down. It also gets a lot worse when i apply the brakes. A bad rim? a flatspot? i'm at a lost here.
Old May 1, 2010 | 05:56 AM
Gevo1's Avatar
is this an aftermarket wheel?
Old May 1, 2010 | 09:10 AM
AesonVirus's Avatar
Start with balancing the wheels
Old May 1, 2010 | 11:06 AM
kool_yaar's Avatar
^+! thats your cheapest option, and if the wheel is bent or damaged they can tell you after putting the wheel on that machine. Then if everything is fine iwth the wheels and balancing then get your alignment checked out.
Old May 1, 2010 | 12:00 PM
muyrec's Avatar
Ah thanks! i will. They are OEM 17's
Old May 2, 2010 | 12:05 AM
tg1234's Avatar
As others said. Get it ballanced to se if they are ballanced. Could be your tire too.
vitamin.v
Nov 7, 2019 06:10 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Danielek
Sep 20, 2015 12:08 PM
migurus
Sep 5, 2015 09:39 PM
itschuckster
Jul 25, 2015 08:07 AM
