Am I crazy?
Old Aug 17, 2010 | 05:08 PM
  #31
LightsOut's Avatar
SIETESG
Originally Posted by 07blkcoupe
Im a fairly new g-owner too did you say that was an 07? I have an 07 coupe and the grill, lights, wing and wheels are different. Do you or anyone know if they started to change these things half way through the year or production run?
07 coupe is a DE motor same car from03-07
07 sedan is 2 generation and has an HR motor. 07-08 and also very similar to a g37
two different cars buddy.
Old Aug 18, 2010 | 11:02 PM
  #32
LakeShore_Slate's Avatar
What's the best way to take the pin strip off!? I got megs ultra cut, anything more helpful?
Old Aug 19, 2010 | 12:02 AM
  #33
rpm&my_G35's Avatar
^ Stick-on or paint?
If its stuck on, heat it and peel then remove remaining glue with an adhesive remover...even WD40 will work. Wash thoroughly when done removing.
Old Aug 19, 2010 | 04:14 PM
  #34
I believe its painted.
Old Aug 19, 2010 | 05:59 PM
  #35
rpm&my_G35's Avatar
Painted - You might have luck with a with lacquer thinner. Apply it wet and let it work a little then it should rub off. Test in an inconspicuous area first.
Hopefully the painted under the stripe is not more intense red than the rest of the car. If the rest of the car has faded a little it may be the case.
Old Aug 19, 2010 | 06:04 PM
  #36
sakataj's Avatar
yes u r crazy.....but that has NOTHING to do with this post
Old Aug 21, 2010 | 10:19 AM
  #37
JZeezG35's Avatar
Yes you are crazy...
Video Share
Jan 31, 2017 04:00 PM
SuperSaiyan
Sep 23, 2015 06:13 PM
reaper76
Sep 20, 2015 11:59 AM
carsmacked71
Sep 18, 2015 04:13 AM
NJ6MT
Sep 10, 2015 08:40 AM
