My G died & I was stranded!!! WTF???
Old Aug 24, 2010 | 11:22 PM
monsta717's Avatar
Originally Posted by Irrelevant
If the dealer is correct and the crankshaft is turning but the cams aren't, the most likely culprit is probably a timing chain or belt.
If this let go, there may be more serious internal damage if a valve and piston tried to occupy the same place in space and time.
The good thing is it seems you should be covered under the powertrain warranty. The bad is it might be a while before you get your car back.
agree, both cams and crank always move together, if they dont mostlikly almost always timing belt or chain
Old Aug 25, 2010 | 08:28 AM
viceversa's Avatar
...chain.
Old Aug 25, 2010 | 09:10 AM
stanfna's Avatar
the Kia is nicer than I expected...but I miss my G !!!!!!
Old Aug 25, 2010 | 09:41 AM
youngG's Avatar
WOW that suck hope everthing goes good
Old Aug 25, 2010 | 11:39 AM
xRayZx's Avatar
damn, good luck man
Old Aug 25, 2010 | 12:38 PM
miltoda's Avatar
well on the bright side, the dealer will basically have to do a 60k maintenance for you by putting in a new engine. I know it sucks, but in the end it's just a car, and you had a warranty for the damage.
Old Aug 25, 2010 | 11:16 PM
monsta717's Avatar
broken time chain= lots of money
car damages= lots of money
buying warranty in the beginning=lots of money
damages while still in warranty..... pricelesss
wish i was still in warranty....
Old Aug 25, 2010 | 11:40 PM
pinkii's Avatar
Mine did that when I first got it....
well I wasnt in cruise control but going about 80 then....nothing.
My battery died. I was able to turn the car on but it was revving near redline and everything else was working except I had no power when I pressed on the gas.
They replaced the battery and smooth sailing after that for a year until the new battery died also. (note to self... dont leave the phone charger plugged in 24/7 in the center console. LOL)
Old Aug 26, 2010 | 04:08 AM
VictoriousG's Avatar
in for results sux about your situation + a kia
Old Aug 27, 2010 | 01:08 PM
stanfna's Avatar
I just realized i posted this in the coupe section...MODS...can you move this to the sedan section?
Thanks and sorry for the confusion.
EDIT: Thanks Grace!
Old Aug 27, 2010 | 04:59 PM
stanfna's Avatar
UPDATE...the dealer just called. he said the timing chain did break. but there was no other damage. they are going to put the motor back together and see how well it runs.
my warranty is up in 8,000 miles. i am a bit nervous. what do you guys think?
Thanks!
Old Aug 27, 2010 | 05:54 PM
Irrelevant's Avatar
Sounds like all should work out well then. You'll have a 62,000 mile engine with a zero mile timing chain.
If there was additional damage internally it should be pretty easy to tell once the new chain is installed.
Yours is the only timing chain failure I've read about to date. Though there may be others it seems like it was probably an isolated incident. I think you can probably sleep well at night once you get your car back and don't notice any additional engine-related issues.
Old Aug 27, 2010 | 08:58 PM
BlkCoupe's Avatar
There are interference engines like the Cadillac CTS 3.6 that when the timing chain breaks the valves hit the piston and significant damage occurs and non-interference engines like the G's that when the timing chain breaks no other damage should occur. If other damage occurs then there was something else going on with your engine prior to the timing chain problem.
Old Aug 27, 2010 | 09:16 PM
NyCSnEaK's Avatar
subscribed...
Old Aug 27, 2010 | 10:43 PM
  #30
herrschaft's Avatar
Thats good to know
