How to associate keys with memory seats...
Old Jan 10, 2011 | 04:53 PM
G3507Tech's Avatar
I bought 2007 G35 4 Door Auto Sedan and I went to dealer to add a key since it came up with one. Dealer said it is recalled and they helped me to replace the existing and programed the other key(paid). He did mention when I asked how to associate the keys with memory seats since me and my wife both use the same car ofcourse we can hit the memory button but instead of hitting the but whenever we open the door it should automatically adjust the seats.
Is it too difficulty to setup?
Thanks for your inputs!
Old Jan 10, 2011 | 07:47 PM
AesonVirus's Avatar
Your answer, I believe, is on page 3-27 in the owner's manual.
Keep in mind, you need the Premium package in order to have the memory function.
http://www.infinitiusa.com/content/d...-G35-Sedan.pdf
Old Jan 10, 2011 | 09:10 PM
G3507Tech's Avatar
I guess, I have memory seats with buttons, Navigation system,blue tooth, 10 spkr Bose, compact flash card but not the rear view cam. I don't know is it called premium ? I am little confused with G35 versions.
I already setup using setting on the screen on exit back to previous stage but I have MDX09 whenever I go to the car and open with second key it goes to memory setting 2 position.
I am looking for the same feature instead of hitting the button to desired position. The key should program with memory settings.
Thanks for the reply..I do check with other dealer see if they can fix it.
Old Jan 11, 2011 | 09:48 AM
AesonVirus's Avatar
For the 2007 model, the G had three available option packages.
The Premium including things like the Homelink Mirror and Memory Seats.
The Navigation included navi and the Musicbox feature
The Tech included the rearview camera and ICC
Sounds like you have Premium/Nav (No Tech)
Did you read the manual?
I provided you with a link and page number.
Activating or canceling function:
The seat synchronization function can be activated or canceled by pressing and holding the SET switch for more than 10 seconds while the ignition switch is in the OFF position.
Canceling the seat synchronization function also cancels the entry/exit function.
The indicator lights of the memory switches (1 and 2) will blink once when
the function is canceled, and the indicator lights will blink twice when the function is activated.
The seat synchronization function can also be canceled if the Lift Steering
Wheel on Exit key or Slide Driver Seat Back on Exit key is turned to OFF (Automatic Transmission models) in the Comfort & Conv settings.
(See VEHICLE INFORMATION AND SETTINGS.)
MEMORY STORAGE
Two positions for the driver's seat, steering column and outside mirrors can
be stored in the automatic drive positioner memory. Follow these procedures
to use the memory system.
1. Automatic transmission models:
Move the selector lever to the P (Park) position.
2. Push the ignition switch to the ON position.
3. Adjust the driver's seat, steering column and outside mirrors to the desired
positions by manually operating each adjusting switch.
4. Push the SET switch and, within 5 seconds, push the memory switch (1 or 2) fully for at least 1 second.
The indicator light for the pushed memory switch will stay on for approximately 5 seconds after pushing the switch.
If memory is stored in the same memory switch, the previous memory
will be deleted.
Old Jan 11, 2011 | 11:12 AM
G3507Tech's Avatar
Thumbs up
MEMORY STORAGE
will be deleted.
Yes, I have gone through the steps which you provide with Manual and I successfully setup the keys with memory settings.
Thank you for your help!
Old Jan 12, 2011 | 09:23 AM
Rutland's Avatar
This doesn't work with the 6MT, right? Haven't tried it, but I think I remember hearing that.
Old Jan 12, 2011 | 12:09 PM
G3507Tech's Avatar
I guess so but mine is Auto.
Old Jan 12, 2011 | 05:58 PM
AesonVirus's Avatar
No, this works on both Auto and Manual models.
For the Manual model, the shift must be in 1st gear or Reverse and the parking brake must be applied to set the memory.
You may be thinking of the option that slides the seat back and the wheel up when you kill the car and open the door. I believe that easy exit option is for Auto's only.
Old Jan 14, 2011 | 04:51 PM
Rutland's Avatar
Yeah, that's what i was talking about...thank you. Sorry for the confusion.
Dallsinghjr1
Sep 17, 2023 11:25 AM
G35xdriver04
Nov 7, 2015 08:31 PM
pasjr1972
Sep 1, 2015 10:17 PM
