Interior Accent Lighting for 2007 G35 ?
Old Jan 26, 2011 | 04:44 PM
G3507Tech's Avatar
I was checking with dealer about accent lighting but dealer said they have for 2010 not for 2007.
Can some one share some info where and how to get them for 2007?
Old Jan 26, 2011 | 10:50 PM
RedBaronK's Avatar
I read on the NICO forums that it does work for 2007...
Old Jan 27, 2011 | 12:17 AM
jbendo's Avatar
Here is a link from Riverside Infiniti's Ebay Store (no I am not advertising):
Riverside Infiniti Ebay Store
Looks like it works for 2007 Sedans.
Old Jan 27, 2011 | 02:07 AM
polo708's Avatar
^^ link doesn't work... is it basically just the floor lighting? Does the wiring harness connect to something or do wires need to be spliced?
Old Jan 27, 2011 | 02:17 AM
jbendo's Avatar
Whoops, I didn't link it correctly , the above post should be fixed now, check it out. Sorry, not too sure on installation, but it says it comes with instructions.
Old Jan 27, 2011 | 03:13 AM
kool_yaar's Avatar
^ whs it an easy but a little time consuming install. u have to drill two holes for the leds on each side lower dash plastic and then the glovebox needs to come out to wire it to the BCM wire as instructed in the installation guide.
kool_yaar's Avatar
it comes with a wire tap so all you have to do is to locate the wire stated in the guide and snap it on.
Old Jan 27, 2011 | 09:59 AM
RedBaronK's Avatar
Does it stay lit the whole time or only when door is opened?
Old Jan 27, 2011 | 05:08 PM
djfarhan's Avatar
https://g35driver.com/forums/media-s...t-kit-oem.html
seller: https://g35driver.com/forums/members...einfiniti.html
Old Jan 27, 2011 | 07:41 PM
kool_yaar's Avatar
it comes on when the door is open or when your headlights are on or auto, they stay on for a while after the doors are closed, you can see when they are on at night through the little crevice
Old Jan 27, 2011 | 07:43 PM
djfarhan's Avatar
^ mine stay on the whole time my heads r on. i thought i was gonna hate it but the lighting is so subtle that it looks good even though it is not bright as the sun
Old Jan 27, 2011 | 09:32 PM
RealMothaEffinG's Avatar
sweeeeet i want.
Old Jan 27, 2011 | 09:36 PM
djfarhan's Avatar
^ PM rick@riversideinfiniti here
Sepsis
Feb 12, 2020 02:05 PM
wonderizm
Sep 24, 2015 03:09 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
