Painting grill?
Old Feb 5, 2011 | 06:30 PM
stl.rbizy's Avatar
Painting grill?
For those of you who have painted your grill...did you tape it and paint it on the car. Or remove and paint?
If remove is it difficult to get grill out?
Old Feb 5, 2011 | 06:40 PM
chink-ah-saur's Avatar
Take if off ...and no just pop the hood and look...6 tabs I think
Old Feb 5, 2011 | 07:08 PM
Greekboy115's Avatar
Here you go. It isn't hard it can just be a little tricky the first time you try to remove it. Just take it slow and you will be fine.
https://g35driver.com/forums/v36-diy...e-removal.html
Good Luck!
Old Feb 5, 2011 | 08:05 PM
salvador312's Avatar
There some people that done it with it on. A lot masking tape! I think it would be quicker taking it off!
Old Feb 5, 2011 | 08:14 PM
JMZ_blkobsidian's Avatar
Take it off
I did mine (in the midnight style). IMO, the best approach is to remove the grill, sand the surfaces to be painted, prime, then paint using a heat-resistant spray (e.g. Duplicolor engine or brake paint).
Old Feb 5, 2011 | 08:33 PM
+1 It doesn't take that long to take off the grille. Why bother risking any over-spray on your paint? Not worth it IMO.
Old Feb 5, 2011 | 08:41 PM
stl.rbizy's Avatar
great write up, after seeing that i will remove and go that route. Thanks for the tips
Old Feb 5, 2011 | 08:59 PM
J2S2M's Avatar
I don't understand the logic of keeping the grill on and painting. How do you sand w/ it on in the first place? You gotta be pretty damn lazy to do a half-as$ job painting your grill on a 40k car. I wouldn't even do that to a Civic.
Do it the right way the first time. I did mine with duplicolor primer and duplicolor bumper coating flat black paint (very durable stuff). It was pretty fun to do it myself and it came out perfect! Just be sure to take your time and let each coat dry before spraying it again. You will be fine!
Old Feb 6, 2011 | 03:11 AM
djfarhan's Avatar
post pics when ur done!
Old Feb 6, 2011 | 08:43 AM
bluedevils95's Avatar
Can't wait to see how you did it.
Picture Share
Feb 4, 2018 12:41 PM
DRG35R
Jan 31, 2016 07:14 AM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
