DIY Lowering - Tight Bolt
Old Feb 15, 2011 | 01:26 AM
joesmithf1's Avatar
Hi you guys, i am trying to DIY on the lowering springs and i can't seem to get the lower end-link bolt to loosen. I tried with a longer breaker bar and nothing. It is so tight that i am concern i might break something if i continue to apply pressure. Suggestion? I also sprayed some W-40, but no luck.
Is it just my G or have you guys gotten the same issue?
Old Feb 15, 2011 | 02:06 AM
InfiniteG35S's Avatar
Cool Tight Bolt
Try "penetrating oil" not WD40... let sit for 15-20 minutes and try with a breaker bar. If it's still seized, repeat steps. Lock Tight's a *****!
Old Feb 15, 2011 | 07:29 AM
soundmike's Avatar
Definitely use something like Liquid Wrench or PB Blaster (i use the latter), let it sit for a few minutes. If it's really tight, like mine was, i sprayed every couple of hours and let it sit overnight.
Also, be sure you have something holding on to the other end of the link -- there's a nut there that will just keep turning if it's not held down.
Old Feb 15, 2011 | 10:33 AM
joesmithf1's Avatar
Thanks guys
Old Feb 15, 2011 | 09:35 PM
stl.rbizy's Avatar
heat it up with a blow torch, just keep clear of the brake lines brake fluid very flamable. i have done this on caliper bracket bolts on my old acura
Old Feb 16, 2011 | 12:20 AM
salvador312's Avatar
I think this is the one I had trouble with! PITA!!!!!!! I even bought a impact gun but no luck, I did it by hand!
Old Feb 16, 2011 | 12:41 AM
joesmithf1's Avatar
Haha I just bought air impact gun today to prep this weekend install!! Hopefully the oil and gun will help. What u mean done by hand?
Old Feb 16, 2011 | 12:49 AM
I returned the gun because I didn't like it. By hand I mean no power tools!!
magnetism80
Feb 1, 2019 10:00 AM
cmesidewayz
Sep 29, 2015 09:28 PM
neight
Interior
Sep 21, 2015 05:35 PM
Machine Head
Sep 4, 2015 07:22 PM
Kicknshift
Sep 3, 2015 09:35 AM
