Auto up on windows not working
Old Feb 20, 2011 | 07:15 PM
stl.rbizy's Avatar
What is the reset for the autoup? It just stopped working on the driver side. The battery didnt die nor was it unhooked. The auto down works and all other windows are just fine.
Sidenote: There is a slight buzzing noise coming from around the fusebox, not sure if that has anything to do with this problem...buzzing started a few days ago, auto up stop working in the middle of a road trip
Old Feb 20, 2011 | 08:20 PM
Texasscout's Avatar
My sunroof did the same thing and I had the dealer reprogram it. He did it while some other work was being done so I don't know how much he charged. G35frenzy.com used to have a PDF of the Service manual, but they ****ed the whole site up and I can't get in unless I register now. That sux.
AesonVirus's Avatar
Not sure about the buzzing, but try to reset the window.
Roll the window down by pushing the button and holding it in as the window rolls down.
When it's all the way down, continue to hold the button for another 5 seconds.
Then, roll the window up by clicking the button up and holding it there.
When the window is all the way up, continue to hold the switch up for another 5 seconds.
Then, try the auto-down and up functions.... you should be all set
Old Feb 20, 2011 | 08:40 PM
salvador312's Avatar
+1!!!! It happened to me and I was panicking!! Just do that and you be set!!
Old Feb 20, 2011 | 08:41 PM
rpm&my_G35's Avatar
from the Sticky https://g35driver.com/forums/g35-sed...edan-faqs.html
https://g35driver.com/forums/1841124-post3.html
Old Feb 20, 2011 | 10:01 PM
stl.rbizy's Avatar
all set, thanks
Old Feb 20, 2011 | 10:13 PM
AesonVirus's Avatar
Originally Posted by stl.rbizy
all set, thanks
Do-Da-Dippety!
Old Feb 21, 2011 | 06:31 PM
djfarhan's Avatar
mine stopped working cuz they opened up the doors to install my LED side mirror blinkers, did what aeson said and it works!
mike730
Jan 12, 2018 04:25 PM
joedaddy1
Jul 28, 2015 02:58 PM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
attarday
Jul 15, 2015 04:03 PM
