lemme shed a lil hope for you guys
Old Mar 8, 2011 | 12:46 PM
freakta's Avatar
thats good to see
Old Mar 8, 2011 | 01:43 PM
soltis007's Avatar
I bought my 07' G to last, and electronics are the only thing that really worries me.
N/A cars are the least maintenance too.
This is one of the best threads I've seen yet - 190k yikes. Thank you much, made my day.
I'm coming from Vdubs which are incredible rides but lots of work. My 1.8t put out a ton of power but every month it was something new. After a while it just gets old. My 2cents is that the VQ35HR engine is pretty hard to beat. Decent power, livable mpg, longevity, low maintenance, sounds good when you want to hear it. What I miss??
Old Mar 8, 2011 | 03:15 PM
LakeShore_Slate's Avatar
Originally Posted by RemmyZero
i'm still hoping to buy a new M before 190k
HAHA, me too!
Old Mar 8, 2011 | 03:32 PM
the_sedan's Avatar
everything on the car worked still btw. the engineers thought JUST a lil harder than they did with the 1g cars. :/ audio units, window/lock motors, cam sensors are NOT common issues with these cars. mainly just the common interior pieces are as common as it gets. along with the front brake judder until you get the updated hardware and backing plates. has my vote for a reliable new infiniti car!
Old Mar 8, 2011 | 04:23 PM
scorpkev's Avatar
G35 Sedan RWD
Can you elaborate more on "updated hardware and backing plates"?
I want to make sure I have what you have as I still have factory warranty. actually more like it is covered under Elite warranty.
Old Mar 8, 2011 | 04:37 PM
greg_atlanta's Avatar
2008 G35 Journey Sedan no sunroof
the_coupe: do you expect similar results from the G37 engine long term? (37VHR)
djfarhan's Avatar
damn, what yr is that 2nd gen? i am planning to upgrade when i hit 100k.
Old Mar 9, 2011 | 07:16 AM
baileyt35's Avatar
Thanks for that info!!!
Old Mar 9, 2011 | 08:02 PM
the_sedan's Avatar
if you look at the backing plate for your front brakes.....you'll notice there isnt much of one....which leaves the entire rotor unprotected from the elements. this makes the front brakes warp easily and gives you a brake judder. if you're still under warranty with a brake pulsation/judder/shake....take it in...they'll perform the bulletin which will turn your rotors, put on the new backing plates and new pads with hardware.
as far as the vq37hr, i'd assume it should be just as reliable. i havent seen one with any problems yet ALTHOUGH there is a TSB for oil consumption on them, another thing i havent seen in a G. so i'd say it is trailing along with the 35 as far as reliability and durability.
and dj...if you could read lol.....the first line says it was an 07 sedan.
Mry
Mar 3, 2023 01:03 AM
bTanz
Oct 15, 2015 02:31 PM
leo38cheng
Aug 17, 2015 12:16 AM
si_driver
Aug 11, 2015 07:08 AM
Frostbite91
Jul 27, 2015 05:25 AM
