wtf...engine oil overfill - worried
Old Mar 21, 2011 | 01:45 PM
scorpkev's Avatar
G35 Sedan RWD
so 5 1/2 quarts save to drive? I assume engine will burn off some oil gradually as you drive.
Old Mar 21, 2011 | 01:47 PM
kool_yaar's Avatar
Originally Posted by scorpkev
Ca sits for 15mins then check, it was almost 1 inch over H.
I decided to get a siphon pump at Pepboys for $12. Could not pump out oil from where u pour oil so I pumped from dipstick, I took out about 1/2 quart. With engine cold, now it sits on H. I assume now it should be safe to drive, right?
an inch over H can not be good, at H is ok but next time you want to keep it just below H
Old Mar 21, 2011 | 02:15 PM
nghiars's Avatar
Originally Posted by Infiniti Chica
If you're really not sure how to proceed, drain some of the oil yourself when the engine is cold. I have a Fumoto valve, makes the job easy and very clean.
the coolest thing ive seen today.
Old Mar 21, 2011 | 04:08 PM
terrycs's Avatar
I always fill up to L, then check the level the next morning. On my motor, it ends up prefectly at around 1/2 way when cold.
@ *****-ah-sore: I think 1/2 quart over 1500 miles is too much. IMO, you are burning too much oil. I don't need to add any over an 8,000 mile interval.
Old Mar 21, 2011 | 09:37 PM
kool_yaar's Avatar
^+1 i have never had to add any oil to my motor between oil changes and keep checking it a few times a month and its perfectly between the L-H area.
Old Mar 21, 2011 | 10:23 PM
vqsmile's Avatar
That's just silly. Why didn't you either go back to the shop and make them do it or just crack the drain plug and let it drain about 3/4 quart ?
Old Mar 21, 2011 | 10:28 PM
Canadian's Avatar
Canada, eh?
^+1 the shop should fix the problem for free. They're the ones you expect to know what they're doing. If you gave them an extra quart of oil, it doesn't mean they have to use it. They should know better. I'd go back there and make sure they fix it.
Old Mar 21, 2011 | 11:00 PM
vqsmile's Avatar
^ He's already done the deed
Old Mar 22, 2011 | 06:57 PM
blnewt's Avatar
5.2 quarts will get you right at the High fill line w/ a new filter change. I'd definately drain that .8 quart, no need to put extra strain on the motor/seals. As far as burning oil, my first G (which I sold a couple years ago) has almost 65k on it and I still change the oil for the gal I sold it to. The oil always is still at the high fill mark. I change the syn oil every
5k and my 09 (w/ 24k) also has NO measureable oil consumption. I'd be pretty concerned if I was the poster that said he's going through .5 quarts every 1500 miles. The VQs really aren't known as oil burners, even at 60k. Sure there are isolated oil consumption issues but it's not very common.
I don't trust anyone to change my oil, I've had incidents like the OPs' gone through enough to just do it myself and rest easy
Old Mar 22, 2011 | 08:49 PM
Infiniti Chica's Avatar
Originally Posted by RemmyZero
i love a woman that does her research!!!
Originally Posted by samsizzle
infinitichica are you single? you have your pick with any guy on this site
yep... very single--- but my appearance and age (see above) seems to be getting me no dates.
Are you saying that it's halfway between L-H? If so, you're running a bit low (~1 qt). I keep it at H or just a smidge below.
Old Mar 22, 2011 | 11:26 PM
chink-ah-saur's Avatar
Yea my baby eats oil like fuuk.
Old Mar 23, 2011 | 07:24 AM
RemmyZero's Avatar
on a side note i've been using fumoto products for about 6 years now and i'll mention that the fumoto valve caused the oil pan on my acura to get ripped off (yes, you read right) by a manhole cover in the street but i blame that more on the local utility who had dug everything up. that being said i still use fumoto products, i am more careful about the clearances to the oil pan.
jeffbdye
Jun 1, 2018 03:51 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DRG35R
Jan 31, 2016 07:14 AM
mbe32
Nov 13, 2015 11:09 PM
Learned Hand
Oct 1, 2015 09:02 AM
