Post Pic Of Your Tire Size 235/30/20 265/30/20
Old May 3, 2011 | 05:51 PM
cfarinasg35's Avatar
Unhappy Post Pic Of Your Tire Size 235/30/20 265/30/20
please help me out on what size tire i should go with. Front 235/30/20 Rear 265/30/20 or Front 245/30/20 Rear 275/30/20 or (275/25/20 rear).
Thank u.
Old May 3, 2011 | 06:17 PM
bluedevils95's Avatar
If you can find my thread on my akebono's i have on the rear 275/35/20. Front is 255/35/20. That should be close enough maybe.
Old May 3, 2011 | 06:45 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
It depends on the width of your wheels and how you want them to fit. 245/30 and 275/30/20 match the factory diameter tires
Old May 3, 2011 | 07:23 PM
Shurik355's Avatar
No you guys are getting it wrong. If he wants to go with 20s and stay in the factory diameter then here are the correct specs you should be looking at...
front 245/35/20 Rear 275/30/20 You can sometimes go with 235 in the front and 265 in the back with slightly stretching.
But that all depends on what kind of rim width you're going with.
Everyone runs a different set up, it all depends you know.
Old May 3, 2011 | 07:34 PM
kool_yaar's Avatar
^+1 if you wanna stay in factory specs like i did with 20s then go with 245/35/20 F and 275/30/20 R. else u can play around with but it might send your speedo out of whack and mess a bit with the VDC imo
Old May 4, 2011 | 01:24 AM
Didn't see this was for V36's.
Yes, 245/35/20F and 275/30/20R are the correct sizes.
Old May 4, 2011 | 11:25 AM
Tire Size
Thank you for the respond, size of the rims are 20+8.5 front and rear 20+10.5 i wanna go with the Stretch look i'm also going low. But also wanna have & idea of the look, so woundering anyone has some pic of that set up.
Old May 4, 2011 | 11:42 AM
blnewt's Avatar
Mine are 245/35/20 on all 4 corners
Old May 4, 2011 | 11:52 AM
no guys, please pic of tire size 235/30/20 & 265/30/20.
Old May 4, 2011 | 11:56 AM
The look im lookin for.
[IMG]C:\Documents and Settings\csc1.CSCMIA.000\My[/IMG]
Old May 4, 2011 | 11:57 AM
Need help posting a pic.
Old May 4, 2011 | 01:12 PM
Those aren't normal sizes for the V36 sp nobody is going to have them, let alone have pictures of exactly what you're looking for.
If you're going low and want stretched tires then I'd go with
225/35/20F
255/35R or the 265/30 will work too, there's just not too many tires made in that size.
Old May 4, 2011 | 02:13 PM
http://www.tirerack.com/tires/TireSe...r=20&x=19&y=11
vitamin.v
Nov 7, 2019 06:10 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
reaper76
Aug 5, 2015 10:13 AM
Popes
Jul 29, 2015 05:07 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
