A/C Fan not blowing
Old Dec 30, 2016 | 01:16 AM
  #31
R2000's Avatar
In pictures
Originally Posted by ACE420
The relay is BEHIND the the panel of fuses where your pedals are..you have to take off the panel that's next to your left foot when sitting in car. And it exposes the panel and two screw on top part of it..unscrew these and panel should slide off rail guide and the two relays are on the back looks like a blue box with prongs
Some pictures for g35 2007/8 +
open fuse area
unscrew this, remove plastic covering
un-clip white fuse block. Unscrew this nut so you can turn teh fuse block around enough to pull out the top relay (no clips, just gently and consistently pull relay)
This top one
replace with 25230-79942
Old Oct 31, 2018 | 08:57 AM
  #32
Danilo Dingle's Avatar
G35X
Relay Replacement Fix
First post to this site, so big thank you to all in helping fix my problem. Had the same issues as everyone on my 07 G35X sedan. Worked the same fix by replacing blower relay. I do have a few points of feedback for my fix on my vehicle. The fuse box is on the left side. After removing the plastic covers to gain access to the fuse box, removing the box itself, only requires pressing down on the plastic tabs to slide off. Based on the FSM, the blower relay is the top relay; however, removing/replacing did not fix. As others pointed out, try removing/replacing the bottom relay. Did that and got the blower running instantly. Based on the FSM, the bottom relay is the ignition relay, so I’m not sure that I read the FSM correctly but in any case it fixed it. Big save in the fix as I just dropped $1400 on my 06 Pathfinder for a bad auxiliary catalytic converter.
Old Oct 31, 2018 | 03:04 PM
  #33
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
2007 sedan should be this orientation.
Old Oct 31, 2018 | 09:05 PM
  #34
G35X
Thanks cleric670. The full drawing in the FSM above does indicate which side is up. If you orient to that then it would appears the blower relay that you circled is up. Either way, was able to get a fix though the help of the folks on this site.
Old Nov 14, 2018 | 01:35 PM
  #35
Ultimate_X's Avatar
Hello guys,
I'm having the same issue with my car except my ac/heat won't blow at all, it just gave out.
check the little fuses had both 10amp blown, replaced-nothing still
I swapped the blue box fuses around all 4 I might add and still nothing, I'd figure if i swapped the accessory box with the blower and test before buying the fuse but it didn't turn on?
is it safe to say it's my blower?
Old Nov 21, 2018 | 12:22 AM
  #36
Ultimate_X's Avatar
Just an update: it was the Blower motor. It was super easy to replace but thanks everyone for the info!
btw the satellite radio started working lol
Old Jun 22, 2019 | 07:37 PM
  #37
S Morillo's Avatar
G35 Coupe
I took off the two screws to the fuse box, but it won't budge off the rails? Is there some hidden screw I'm missing? Or do you have a tip how to get it off ACE420? My kid wants to drive it, but I don't want her to suffer without AC.
Mine is a 2006 Infiniti G35 Coupe. Thank you for any help you can shed.
Old Sep 28, 2019 | 04:09 PM
  #38
L.D L's Avatar
Infiniti m35x
Originally Posted by kelvin21
i have a 2007 g35x and im encountering the same problem but i cant seem to find where the relay is can u please let me know where the relay is located in the car your help will be greatly appreciated
G35 relay is behind the fuse box down by your feet.
I'm having the same issue with my m35x 06.. shes an old girl and I've been having electrical problems lately but repairing myself as they occur. The air thing just started happening day before yesterday and its 1 million degrees in Louisiana 🥵
Old Sep 29, 2019 | 11:32 AM
  #39
S Morillo's Avatar
G35 Coupe
Ac
Take off the screws. The panel is plastic and has a small clamp in the middle which u can use a small flat screwdriver to gently insert to unlatch it. Then it should easily slide off. Use needle nose pliers to remove the relays. It took me a while, but once I found that latch, it slid off like butter.
G35Rican
Jul 31, 2024 01:37 AM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
master111
Sep 25, 2015 08:32 PM
mattdg35
Sep 14, 2015 11:28 AM
