sunroof problems
Old 05-25-2011, 12:26 PM
mdailey's Avatar
sunroof problems
sunroof is stuck in the tilt open position... Found 2 loose screws from the sunroof motor after partially pulling down headliner. Re-inserted screws but the sunroof still won't close. Motor is working, but the sunroof only moves an inch. Any solutions?
Old 05-25-2011, 12:29 PM
faiz23's Avatar
ummmm....warranty????
Old 05-25-2011, 01:10 PM
bluedevils95's Avatar
Your motor could be dead or it could be one of the connection. When you push a button do you hear the motor working?
Old 05-25-2011, 01:18 PM
kool_yaar's Avatar
^ well he said his motor is working fine so im guessing its just off the rails really. take car to dealer if u still have warranty.
Old 05-25-2011, 01:24 PM
I hope you still have warranty on your G!
Old 05-25-2011, 01:54 PM
mdailey's Avatar
80k miles...
Old 05-25-2011, 10:15 PM
So, what's going on w/ this thing?
Old 05-25-2011, 11:16 PM
PursuitofG's Avatar
i had the same problem (stuck in tilted position and grinding noise when attempting to open/close), took it to the dealer and the screws were out and needed to tightened. there are some other threads on this.
Old 05-25-2011, 11:24 PM
Really? the screws were out? Did they say what caused it?
Old 05-26-2011, 10:33 AM
mdailey's Avatar
Tightened all 3 screws late last night and got it to close properly. Thank goodness, supposed to rain for the next 2 days...
Old 05-26-2011, 11:20 AM
The dealers didn't want to fix it. It's not under warranty?
Old 05-26-2011, 12:41 PM
mdailey's Avatar
Not after 60k miles... They wanted $125 just to look at it. I figured I'd play with it and see if I could fix it myself.
Old 05-26-2011, 07:41 PM
125 for that?!? no way!
Old 05-26-2011, 08:21 PM
vqsmile's Avatar
Is this a common problem then, that these screws come loose? Might be good to get some pics to show folks which ones so we can do some preemptive maintenance.
Old 05-26-2011, 08:25 PM
Sylvan lake V35's Avatar
Search it, i dont have time find the thread right now but you can reset it by holding the button down and opening and closing it. Mine did the same thing and i pushed it down while pushing the button to get it closed. After that I had to reset it, i bumped the thread last month.
Quick Reply: sunroof problems
