08 350z springs/struts on 08 sedan? (I searched, cannot find the answer!)
Old Jun 10, 2011 | 10:51 AM
Sprockethead's Avatar
I know somebody that has 2008 350z shocks/struts and springs laying around.
Is it possible to put these on my 08 sedan to see what kind of drop I get? It would be cheaper than buying new coilovers. So if it works, it would be a great money-saver for me.
Sorry if this is common knowledge. I searched the forums but could not find an answer.
Thanks to anyone that can help me out.
Old Jun 10, 2011 | 12:05 PM
rpm&my_G35's Avatar
I'm guessing you've seen this springs thread although the shocks where not used. The rears are nor compatible between the 350 and the G either. Only front springs. The 350/370 rear springs are too short to use for the G. I put 370Z front springs on the fronts only.
https://g35driver.com/forums/v36-bra...xperiment.html
Old Jun 10, 2011 | 01:11 PM
I have, thanks, though. That thread is discussing the 370, though, right?
This guy that selling them to me is assuring me that his friend has the same setup (350z/G35sedan) I'm suspicious that nothing has ever been posted here on the same setup, though.
Old Jun 10, 2011 | 06:57 PM
stardust's Avatar
I'm 99.99% sure 350z springs were discussed in that thread
Old Jun 10, 2011 | 07:24 PM
rpm&my_G35's Avatar
Correct. You can't use 350Z coil spring...just the 370Z coil springs fit and only the fronts.
Old Jun 10, 2011 | 07:28 PM
Thank you. You guys just potentially saved me $400. That thread is a little confusing to me.
By the way, I see in your sig that's exactly what you've done. Is it .5 in the front and 1 inch in the back as noted in the referenced thread?
Old Jun 10, 2011 | 08:12 PM
rpm&my_G35's Avatar
Other way around.
The 370Z springs installed on the front will result in a 7/8" drop on a G35X. The shaved rear spring mounts can lower you upto 3/4"...depending how much you cut off. Mine have 5/8" cut off, therefore the rear is that much lower than OEM.
https://g35driver.com/forums/brakes-...mount-mod.html
This is a smaller/shorter thread that I started after I did mine.
https://g35driver.com/forums/canada/...new-smile.html
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
RA102223
Intake & Exhaust
Jul 25, 2015 01:03 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
MT6002
Lighting
Jul 21, 2015 01:13 PM
