really noob jack question
Old Jun 11, 2011 | 02:39 AM
platinumg35x's Avatar
tried searching but couldn't find the answer. i've never jacked up this car before using a floor jack, always used the standard jack that came with the car. I wanna jack up the front of my car (just one side). Can I do it by jacking up on the spot shown in the pic...using the craftsman 2.25 ton floor jack. thanks
Old Jun 11, 2011 | 02:51 AM
E-Ticket Ride's Avatar
Just use the forward pinch weld under the sideskirts and you won't have a problem.
Old Jun 11, 2011 | 03:04 AM
RedBaronK's Avatar
The side skirts sometimes bend under the pressure of the jacks though...unless u use a piece of wood or a hockey puck to absorb the pressure.
Old Jun 11, 2011 | 03:07 AM
faiz23's Avatar
JACK POINTS
Old Jun 11, 2011 | 03:21 AM
kool_yaar's Avatar
^+1 the pinch welds have enough area around them for almost all hydraulic floor jacks with circular plates to lift the car without touching or damaging sideskirts, but make sure you are not in contact with SK when lifting.
else like redbaron said using a piece of wood or better yet a slit hockey puck will ensure even safer lifting.
Old Jun 11, 2011 | 03:48 AM
lefizzet's Avatar
+1 I just place a hockey puck on my jack and use the 4 corners
Old Jun 11, 2011 | 07:47 AM
soundmike's Avatar
The only problem with lifting the car by the pinch welds using a jack, is that you can't put a jack stand there, so you're at the mercy of the jack holding the car up (not good).
Try lifting from the front center position, once the car is up, place the jack stand on the pinch weld and lower the car back down.
Old Jun 16, 2011 | 12:08 AM
thanks for the responses guys. tried it at the pinch welds and they were just bending. didn't want to jack from the center position, although that would have been ideal, because my jack was too short. so i jacked up the car from the area right behind the pinch welds near the front tire. part of the area has this rubberish cloth (?) so it provided with good grip.
Xfactor
Dec 1, 2019 12:52 PM
b2autodesigns
Accessories-Vendor
70
Feb 25, 2017 01:12 PM
as25656800
Aug 9, 2015 07:25 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
DRG35R
Jul 31, 2015 10:23 AM
