squeeling windows
squeeling windows
anyone experiencing this problem? when I had warrenty the dealer told me to add silicon grease to the sides of the rubber the windows touches which solved the problem for a little bit but now it still squeels even when I apply generous amounts of grease. Is there another spot im missing?
i used to have this problem in the first year i got the car, i sprayed some silicone spray into the sides of the window using the red pipe extension and have not had any problem since...
Cool! Ill Give it a try.
It's just the tracks need lubricating, depending on what type of squeak it is. Could be one of the mechanical parts inside ie reguator. My passenger side was doing it about 3 months ago and would be slow to go down. I was still under warranty, and took it in. All they did was lubricated the tracks and problem solved.
Thanks- mine just started this week doing this, I was thinking the motor was the reason it was going slow, but then the squeaks started.. I'll try spraying grease first and if I must, I'll remove the door panel and try the pads.
BradMD_96
Oct 6, 2015 09:31 AM
Learned Hand
Oct 1, 2015 09:02 AM
