2nd Gen Random Little Question Thread!
Old Oct 11, 2016 | 04:25 PM
  #241
b-dRizZy's Avatar
no problem
lol yeah I wouldn't do ebay on these cars just saying!
Or as typical you wont get what you order, so just avoid it
Old Nov 28, 2017 | 01:01 PM
  #242
dsnowman34's Avatar
Anyone know what this is called? or the part number? (The brown and grey plugs + wire) It plugs into the fusible link at by the positive battery terminal. It's on a 2007 g35x. It looks mine is melted a little, and I unplugged it and it won't plug back in. Looking for a new plug and the wire that is attached to it.
Old Dec 1, 2017 | 04:40 PM
  #243
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yes that is your fusible link and yes the harness is melted. Unfortunately the wiring harness is literally one piece for the entire engine compartment, every sensor, everything. You should check wrecking yards in your area for a compatible match and cut the harness from it and splice into your harness. Take it to a reputable stereo shop in your area if you aren't familiar with how to make a soldered connection and shrink tube.
The fusible link itself is easy and you can buy a replacement from any parts house, it's ok to go Non-OEM for that part.
Old Dec 1, 2017 | 07:35 PM
  #244
dsnowman34's Avatar
Thanks for the info.
Old Jan 11, 2018 | 07:15 PM
  #245
sammy Farhat's Avatar
G35 v M35
Little inexperienced but do exhaust and body kits made for g35 sedans fit on m35 sedans?
Old Jan 11, 2018 | 08:30 PM
  #246
dsnowman34's Avatar
This was very helpful info. The wiring harness is easy to find on ebay, however, in most cases, the plugs aren't included. I finally found one with the plugs included, and had someone come over and splice it together for me for $75.
Old Jan 11, 2018 | 09:13 PM
  #247
cleric670's Avatar
BANNED!!!
Win! Glad you got that all squared away.
Old Apr 11, 2018 | 12:52 AM
  #248
Silversleeper86's Avatar
G35 Sport Sedan 5AT
My clock has a bad backlight led (or whatever it uses). It flickers a lot. Was wondering if it's easy to replace the clock?
Old Apr 11, 2018 | 05:24 AM
  #249
sjwtriggerer's Avatar
I have the typical collapsed driver's seat bolster on the left side of the seat. What's the cheapest way to have this fixed for someone who sucks at DIY and doesn't have the tools anyway?
Old Apr 11, 2018 | 11:20 AM
  #250
cleric670's Avatar
BANNED!!!
You should first try just removing the clock/compass and cleaning up the connectors on the lamps it might be something simple causing the flicker. Earlier G35 clocks are simple and the individual lamps are replaceable, they remind me of older christmas tree lights. Unsure of the newer clock that has the compass and other ATC display stuff.
Call around to body shops and find out who in your area does automotive upholstry, make sure they're aware of the SRS seats but you can probably find someone who can do just that bolster for pretty cheap.
Old Oct 10, 2018 | 04:19 PM
  #251
Mikeg47's Avatar
X pipe part number for 08 sedan
What’s up everyone. So I have installed test pipes and want to install a magnaflow resonated x pipe and am unsure what part to order and frankly where to put it. Some people have replaced resonators with them but I was wondering if the y pipe is the better place to install. I also have a muffler delete so bottom line I need help with the proper part number to fit my stock piping and whether to put it in where the y is or in the resonators so that I can clean up some of the rasp. Any advice is greatly appreciated. (Chose this thread hoping that I would actually receive some advice rather than my question going unnoticed in the exhaust threads)
Last edited by Mikeg47; Oct 10, 2018 at 04:21 PM. Reason: Missed key point with thread
Old Nov 27, 2018 | 06:06 PM
  #252
stevedunn68's Avatar
stock
Need help please, 08 g35
The windows , alarm, interior lights and the wind shield wipers stopped working.. the key in the door rolled the windows down but will not roll them up so i cant drive the car because its too cold or raining. anyone know how to get them rolled up? can i hook a battery to the wires? the fuses look good when i pulled them out in the inside and the fuses by the battery.the fob will unlock the doors but will not lock them. weird deal
the car was hit in the rear end and wondering if there are sensors in the bumper that can short out???
thanks for the help
Old Jan 2, 2019 | 11:13 AM
  #253
DavidChalk's Avatar
Infiniti g35 Sport
2008 G35 Sport Sedan
Hello, I recently Just bought a 2008 Infiniti G35 Sport, I have always loved that car. However I am looking to install a different set of headlights. I can’t seem to find any black housing headlights for my year, so I was wondering if a pair of 2008-2010 g37 headlights could fit my g35 sport sedan? Thank you in advance!!
Old Jan 9, 2019 | 12:44 AM
  #254
G35 Sport Sedan 5AT
Negative
Old Nov 12, 2019 | 09:37 PM
  #255
Ketchup83se01's Avatar
Anybody got a link where i can buy the front and rear door trim that peals of ? Trying to see if there's any deals out there lol
