2nd Gen Random Little Question Thread!
Old Sep 11, 2013 | 02:40 PM
  #196
Jdminfiniti's Avatar
Where are you located?
Old Sep 11, 2013 | 05:15 PM
  #197
vqsmile's Avatar
Maybe here:
Old Oct 26, 2013 | 12:34 PM
  #198
tgeml's Avatar
Just bought a 2008 G35x with 75k on the odometer, is it normal behavior for the front portion of the hood(Nearest to the windshield) to slightly bounce/flex on bumpy roads? Anyone ever fixed this problem?
Old Nov 13, 2013 | 04:15 AM
  #199
Gooniej12's Avatar
Originally Posted by pwntu
Whats wrong with your chrome trim? Why does it need to be replaced?
If you want it a different color i would suggest vinyl wrapping.
Heres the DIY i followed for that by Blnewt
http://www.myg37.com/forums/d-i-y-in...-g-sedans.html
Don't want it a different color. I think the clip that holds the chrome trim is broken? The trim slants up. The trim that is above the door handle on the front passenger door.
Old Nov 13, 2013 | 06:26 AM
  #200
VT's G35S Sedan's Avatar
Hey people, I am currently on my second V36 sedan and just noticed somethingweird.... I drive the car til the fuel range says 10miles or less. But can only fill up 17 galons. According to all the spec web sites I have checked out, our tanks are suppose to hold 20 gallons??
Anyone else have this going on?? and It seems Im only able to get 300 miles out of a full tank, which was not the case on my first one.
Current mods- Top Speed exhaust and Weapon-R intakes and grounded.
Old Nov 13, 2013 | 12:18 PM
  #201
tgeml's Avatar
I notice this as well, the last time I filled up i was at 40 miles remaining(Should have been able to put 18 gallons roughly into the tank), I was only able to put 16 gallons in. For reference I drive a 2008 G35x w/ 76k on the odometer. I'm beginning to believe that this is normal.
Old Nov 13, 2013 | 10:34 PM
  #202
My current one is a 2008 G35S Sedan. What is your average MPG??
I drive 65% on the freeway on cruise control and 35% in the city at stop and go situations and my average is usually 17.8mpg..
My first v36 sedan, a 2007 G35S sedan averaged at 18.9mpg.
I Moved my exhaust, intake and all other parts off of that one and onto this one.
The engine looks clean, no oil leakage. Just that annoying issue with the Fan on full blast for no reason.
Old Nov 22, 2013 | 01:38 PM
  #203
vqsmile's Avatar
Can't believe this is still being questioned; it's been beaten to death many, many times. The fuel gauge system in the car is deliberately set up with a reserve of about 2.5 gallons so that you don't run out.
Old Dec 14, 2013 | 04:40 PM
  #204
pwntu's Avatar
Has anyone ever gotten the maintenance sign come up in between the speedometers? Im thinking its my belts that need to be changed, if i do it myself, will this go away?
Old Dec 14, 2013 | 04:54 PM
  #205
vqsmile's Avatar
Sure, they used to come up until I turned the reminders off.
Are you sure this is just the Maintenance indicator though? What type maintenance did it trigger for (engine oil, oil filter, tires, other) ?? Since you mention belts, it made me wonder. I just want to be sure you aren't seeing a "Service Engine Soon" indicator light.
Of course this is all covered very clearly in the . . .
wait for it . . .
OWNERS MANUAL !!
(On or around Chapter 2, pages 19-20 and 25-29)
Old Dec 14, 2013 | 04:59 PM
  #206
pwntu's Avatar
wait for it . . .
OWNERS MANUAL !!
No, its not the service engine soon light. Its coming up on the screen inbetween the speedometers, where the mpg, temperature etc comes up. It just says maintenance needed soon. Is this something i need to worry about? Is it possible to turn this reminder off?
Old Dec 14, 2013 | 05:12 PM
  #207
vqsmile's Avatar
Quit being lazy.
It's all covered in the manual. If you don't have one, it's time you got one. You can download it (for free) by simply registering here : http://x.infinitihelp.com/forum/loca...6#.UqzWPrQXHDw
I even told you page number!
Old Dec 19, 2013 | 10:48 AM
  #208
Gooniej12's Avatar
Anybody know what kind of bulb is needed for the 2nd gen sedan fog light?
Old Dec 19, 2013 | 01:08 PM
  #209
vqsmile's Avatar
Look on or about page 8-26 in the Owners Manual
Old Dec 20, 2013 | 10:21 PM
  #210
pwntu's Avatar
I get these squealing noise coming from the engine only when its cold outside, usually freezing or below. It sounds like one of the belts. Does anyone know whats wrong?
