Changed front brakes pads and rotors today - and a few Q's
Old Jul 22, 2011 | 04:58 PM
treacherous's Avatar
20 Year Member
G35x
I changed my front brakes pads and rotors today. Hardest part was getting the bolts that hold the caliper bracket off. There is no way they were tightened to 98 ft/lbs as per FSM. I could not get my impact wrench into this spot so ended up reaming on a breaker bar to get it loose with all of my body weight. I didn't think I was going to be able to get the passenger side ones loose but they finally gave.
Another question: I notice in FSM they show single and double piston calipers. Which models have the single piston? Mine was the double piston type.
Just so I know brake judder TSB was fully performed in the past is this the splash shield that went on with TSB? Or is there another shield that is missing? I thought this shield was the stock one.
Driver side rotor was loose and easy to get off. Passenger side needed a little tap from a rubber mallet. I put some anti-sieze on so the rotors will fall off easily when replaced in the future.
Old Jul 22, 2011 | 05:04 PM
InfinitJazz's Avatar
Mine doesn't have that splash shield, so yes, that shield is what went on with the TSB.
Old Jul 22, 2011 | 05:07 PM
CalsonicVQ's Avatar
The G35S sport brakes use the larger single piston. The Journey/X brakes use the smaller dual pistons.
Old Jul 23, 2011 | 01:50 AM
kool_yaar's Avatar
^ whs, if you have smaller double pistons than you have non-sports
kinetek
Aug 3, 2015 04:25 PM
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
wojowojo16
Jul 27, 2015 09:57 AM
emorehs
Jul 17, 2015 09:45 AM
