Where were the ABS brakes?
Old 08-30-2011, 11:25 AM
soundmike's Avatar
There are many factors to consider. Even the rubber compound will affect whether or not it will screech, and if it does, how loudly.
FWIW, when i got into an accident a month ago the tires slid (no screech). If i only kept the pedal where it was the car would've stopped before hitting the next car. But, alas, i stepped further so ABS kicked in and the car felt like it went forward faster from inertia and the rapid pulse stops. It was a straight-line stop, completely dry 105 degree weather.
Old 08-30-2011, 05:41 PM
Anton_Chigurh's Avatar
Originally Posted by AesonVirus
The question is, should the tires screech when the ABS brakes are slammed.
Yes, rubber on pavement can and will scream, even if the ABS is engaging.
If you are questioning whether or not they are functioning, then the question of "did the brake pedal pulse under your foot" comes in. It should feel (and sound) like the brake pedal is ratcheting under your foot.
Most often, if there's something wrong with the system, your ABS light would be on.
I figure, if you didn't hit the guy, they're working.
Don't remember if the pedal was pulsating under my foot
Old 08-30-2011, 07:35 PM
armoredmoonman's Avatar
Old 09-04-2011, 10:57 AM
Kamikazejs's Avatar
^^^^ Wow, enough said. Yeah, static coef. of friction >> kinetic coef. of friction.
Old 09-04-2011, 11:03 AM
ge35es's Avatar
i teach this stuff in performace driving classes..
abs brakes allow approx 5 % traction loss depending on the car...
they are primarly intended for you to be able to apple maxumum braking force
at impending lockup and to be also able to steer your way around an obsticle
rather than just trying to stop. In the sand or loose gravel... yes they may
cause longer braking distances. Locking up on these surfaces actually can
reduce braking distances due to the piling up of the sand or gravel in front
the tire...
in all cases though... tire condition and brake component condition is the chief
contributor to the efficiency of stopping the car.
we used to shut off the abs do demonstrate that it is possibe to learn and
practice threshold braking with out it.
the next trick is left foot braking
05-22-2022 09:26 AM
THMotorsports
Suspension-Vendor
257
12-18-2018 05:43 PM
Gabe83714
10-06-2015 06:40 AM
dcsbh1
10-01-2015 03:15 PM
alinero718
09-27-2015 09:35 PM
Quick Reply: Where were the ABS brakes?
