Correct tire size for the M45 sport rims on G35x
Old Jan 12, 2012 | 09:21 PM
Mixx35's Avatar
i need to buy new tires for the winter......anyone have input as to whether i should buy 245/40/19 or 245/35/19?
Thanks for the help
Old Jan 12, 2012 | 11:13 PM
drivethefive's Avatar
I'd go with the 40 for winter driving for sure...
Old Jan 12, 2012 | 11:22 PM
Mixx35's Avatar
this may be a stupid question, but what are the advantages to having a higher profile?
Old Jan 12, 2012 | 11:49 PM
blnewt's Avatar
You should get the size that has the same diameter as your stock tires' diameter
Old Jan 13, 2012 | 01:45 AM
Anton_Chigurh's Avatar
Smoother ride...more rubber between you and the road...low profiles like 20-30 will ride rougher or harsher than say a 50 or 55. Feel less bumps with higher profile..but you see more tire..which some people hate
Old Jan 13, 2012 | 02:46 AM
J2S2M's Avatar
245/40/19 would be the ideal size. That would be closest to your overall diameter of OEM set up.
Old Jan 13, 2012 | 01:11 PM
vqsmile's Avatar
+1
Can't get any closer than dead on.
Old Jan 13, 2012 | 02:27 PM
J2S2M's Avatar
I ran those sizes when I had the M wheels too. No need to drop to 35 series. You will just have more wheel gap. I would just keep it at 40 series especially for your winter set up.
Old Jan 13, 2012 | 02:36 PM
vqsmile's Avatar
^^ besides the fact that a 245/35 is almost an inch shorter in diameter than stock.
Old Jan 13, 2012 | 05:20 PM
J2S2M's Avatar
Yep. I am currently on 245/35/19's all around on 19x8.5 (+22et). I think I will go back to my 245/40/19's for my next set.
Old Jan 13, 2012 | 05:27 PM
Mixx35's Avatar
thanks for the input...i think i know where my decision stands...
Old Jan 13, 2012 | 09:37 PM
Mixx35's Avatar
sorry failed to mention i am lowered on eibach pro kit.....should i still go with the 40 series or the 35??
Old Jan 13, 2012 | 10:34 PM
mishmosh's Avatar
Yeah, 40 series.
When you say you need new tires for winter, you are talking about all seasons right? Not winter tires. For winter, I would do 225 wide tires.
Old Jan 13, 2012 | 10:56 PM
blnewt's Avatar
The main consideration is diameter, you want to be within 3% +/- of the stock diameter, if it's more than 3% it supposedly causes VDC & ABS issues, and also quite a bit of difference in your actual speed compared to the speedo reading.
vitamin.v
Nov 7, 2019 06:10 PM
R350k5
Oct 1, 2015 08:41 PM
Jnm07
Aug 6, 2015 03:03 AM
reaper76
Aug 5, 2015 10:13 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
