remove seats helpseat
edit... no need to disconnect the battery but you can if it gives you a piece of mind and u dont mind having to reset/resave your memory settings, windows auto feature radio stations and other minor things
EDIT: yup muyrec, ur right after watching the video i think i remember seeing a SRS tag on the sides of the seats but like norcal said u dint have to disconnect batt
huh i thought it did? i remember seeing a crashed G35 and the bags popped out from the sides of the seat. You can clearly see it pop out in this video. It's from a 06 though. at 15 secs in
Yup I have had the seat out of my g before and I didn't deconect the bat and it was fine and u can get the carpet so clean with the seats out it will blow the mind the change u see and the stuff u find under ther lol
Confirmed, we do have front seat torso airbags, in addition to front and rear curtain.
Safety first
http://www.youtube.com/watch?v=adnge...ature=youtu.be
Infiniti G35
2007-08 models
SIDE IMPACT TEST WITH STANDARD FRONT AND REAR HEAD CURTAIN AIRBAGS AND STANDARD FRONT SEAT-MOUNTED TORSO AIRBAGS
OVERALL EVALUATION: Good
Injury measures Head protection Structure/safety cage
Head/neck Torso Pelvis/leg
Driver Good Good Good Good Acceptable
Rear passenger Good Good Good Good
Important: Side impact crash test ratings can be compared across vehicle type and weight categories.
Test details:
The Infiniti G35 was redesigned for the 2007 model year.
Injury measures:
Driver — Measures taken from the dummy indicate a low risk of any significant injuries in a crash of this severity.
Rear passenger — Measures taken from the dummy indicate a low risk of any significant injuries in a crash of this severity.
Head protection:
Driver — The dummy's head was protected from being hit by any hard structures, including the intruding barrier, by a side curtain airbag that deployed from the roof and a side airbag that deployed from the seat.
Rear passenger — The dummy's head was protected from being hit by any hard structures, including the intruding barrier, by a side curtain airbag that deployed from the roof.
Safety first
Infiniti G35
2007-08 models
Test details:
Injury measures:
Head protection:
Okay also am i able to drive without having a pass side front seat. I don't want the airbag to deploy while im driving to the place to get my car detailed. And also what tools did u guys use? Thanks everyone for the info
