At what milage do you have to clean the throttle body?
Old May 28, 2012 | 03:06 PM
Mr.tnismo's Avatar
If you know what your doing there is nothing to fear. Using cheap gas and motor oil will cause more carbon build up in areas like the throttle body. Its a good rule of thumb to clean it out ever 60k miles or so.
Old May 28, 2012 | 03:24 PM
RedBaronK's Avatar
Wait a minute... the throttle body sucks in the air from the outside, so using cheap gas in your car wouldn't affect it.... if the other drivers that u r driving behind r, that would since ur sucking the fumes in.
Old May 28, 2012 | 03:37 PM
Mr.tnismo's Avatar
Carbon deposits in the TB usually come for oil vapors by the PCV.
Old May 29, 2012 | 12:27 AM
Q8y_drifter's Avatar
I clean mine every 20K, which is basically the rate at which I experience idle issues.
Old Apr 7, 2014 | 05:39 AM
ikari's Avatar
My G35 is at 75k and I'm taking it in to have a number of routine things done, should I do this as a matter of priority? Car idles with a bit of unsteadiness, but not to the degree I would be concerned about otherwise ...
Old Apr 7, 2014 | 09:32 AM
LoSt180's Avatar
Just cleaned mine yesterday at 155K when I removed the intake to do my annual K&N filter cleaning. The front wasn't that bad, but when I removed the TB and saw the backside eww. Had to use a toothbrush to get the buildup off. After doing the idle air reset pedal dance thing my idle is back down to normal with the added benefit of being smooth as a whistle. Engine used to vibrate a lot a idle and I was tempted to bump the idle up some, now I don't need to.
Old May 20, 2014 | 10:23 PM
silverG2007's Avatar
Every time I think about doing this... I read a few threads about people who killed their TB and had to spend hundreds on a new one.
Doesn't seem worth the risk.
Old May 21, 2014 | 12:43 PM
stockae92's Avatar
I am going to get mine done at a Nissan dealer, so hopefully it would cost less than doing that at an Infiniti dealer
Freeman186
Sep 6, 2023 10:07 AM
andy350gt
Sep 13, 2015 04:10 PM
esotericrider
Northern California
Sep 10, 2015 02:28 AM
Chadwick Arnold
Sep 9, 2015 02:59 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
