Fuel Injection Service...yes or no?
Old Jun 7, 2012 | 03:39 PM
bat6wc's Avatar
So I have the car at the dealer again for another failed AC Compressor. They are replacing it again under warranty. The past 2 times Ive been at the dealer, they said they strongly recommend i do the Fuel Injection Cleaning Service for $144. Is this just the dealer trying to make some money or is this needed? Im at 48k miles and 4 years and its never been done before. Thoughts?
Old Jun 7, 2012 | 03:41 PM
mathnerd88's Avatar
Don't need it, I've never done it in my car and it's at 66k miles and the motor still runs like new. All you really need is to change your oils (Tranny, Engine, Differential/Transfer) periodically to keep it running in tip top shape. Also, you should inspect the belt and see if it is worn or not. Otherwise, doing any "cleaning" service is unnecessary to your engine and probably won't do anything as long as you maintain it well.
Old Jun 7, 2012 | 04:49 PM
bat6wc's Avatar
they say its a 1 hour Pressure system process that cleans inside and outside of the injectors. They said they insert hoses through the intake to remove all the carbon build up. bs?
Old Jun 7, 2012 | 05:04 PM
mathnerd88's Avatar
I mean there will always be carbon build up, but not enough to do anything to your engine. There are supposed to be detergents in gas that already minimize that so there shouldn't be a massive carbon build up unless your engine isn't burning efficiently.
If you don't notice anything weird going on with your idling/engine, I wouldn't touch it.
Old Jun 7, 2012 | 05:05 PM
kool_yaar's Avatar
since we use 93 premium already the include all sorts of cleaners in em so you dont need this service, if you still want to do it then get a complete fuel system cleaner in a bottle for ~$5 and youre done or use the new seafoam sprayer that attaches to the intake for cleaning for ~$8
Old Jun 7, 2012 | 09:58 PM
bat6wc's Avatar
exactly my thoughts. Passing on this service. Thanks
Old Jun 8, 2012 | 12:49 AM
vqsmile's Avatar
Using 'top tier' gasoline brands will pretty much insure you won't need to do an injector cleaning service. Beyond that, it's true that using premium generally means you get more detergents and additives in the fuel as well. If you can't go for the top tier brands, then add a bottle of Techron additive at least quarterly and you should still be fine. The dealers pretty much make bank off of those FI cleaner services.
Old Jun 8, 2012 | 01:15 AM
mathnerd88's Avatar
Even then, I feel like TopTier Gasoline is being paid by these companies to promote their gas. Have you noticed that almost all of the brands listed are from major oil companies? At first it was only a select few, such as Shell with their Nitrogen enriched gasoline. Exxon/Mobil wasn't on that list until recently. The gas is the same, but the detergents and additive packages are different across the brand...but they all have to adhere to a standard issued by the government. It's like putting Synthetic Oil vs. Dino Oil in your engine. As long as you keep the maintenance up and good, you will most likely not notice a difference.
Major companies I don't see up there are BP and Sunoco.
Granted, I still only use Mobil 93 Premium in my G.
Old Jun 8, 2012 | 01:41 AM
thescreensavers's Avatar
Mr.202?
I wouldn't put faith in "top tier" its being shown time and time again its means jack.
Techron Additive contains PEA, which is in Chevron Gas. Its the only proven concentrate that actually cleans deposits.
Furthermore there are a few other Fuel system cleaners that have PEA, those are the only ones you should by not ones which are 98% Kerosene.
Old Jun 8, 2012 | 12:07 PM
vqsmile's Avatar
Hmm . . . I have a close personal friend that is a chemical engineer, recently retired after working for Chevron for 40 years, and is named in person on the actual patent for the Techron additive. According to him, in years past, Chevron really did have a leg up on the other major companies and actually sold additives to some of them under license so they could meet minimum top-tier status, all the while, they maintained a healthy advantage beyond the others even within the top-tier though. However, in the past few years though, he claims other major companies have developed or licensed replacement additives of similar quality to Techron and are successfully achieving performance similar to Chevron. He commented that, anymore, buying from a top tier company like Chevron, Shell, Conoco Phillips, etc., will provide all the detergents necessary to maintain proper cleanliness.
Old Jun 8, 2012 | 02:17 PM
drivethefive's Avatar
Uh oh, this is turing into another gas thread lol. Bat, I would pass on the service too, others have said it already, the detergents used in our gas now will do sufficient cleansing of the fuel system. The fuel system cleaners may go a step further but getting it done from the dealer is not necessary. You going to Plaza or Bommarito?
Old Jun 8, 2012 | 10:31 PM
jomamahama's Avatar
Waste of money even if it's $8 from the bottle. These things sell just for the placebo effect
Old Jun 8, 2012 | 11:09 PM
kool_yaar's Avatar
imo seafoam does actually work on higher mileage cars if you do some research. personally the mpgs iv gained in all my previous cars through this process has been well worth the $8
Old Jun 8, 2012 | 11:15 PM
Anton_Chigurh's Avatar
No need and you should never have to do it if you take care of the car
Dallsinghjr1
Sep 17, 2023 11:25 AM
g.spot
May 9, 2016 10:54 PM
9tray turbo
Sep 29, 2015 10:22 PM
Hogbone
Sep 28, 2015 06:44 PM
Rhinos7777
Sep 6, 2015 05:36 PM
