spacers/rubbing
spacers/rubbing
Hey guys, I'm new so don't beat me up too bad. Yes I've searched this forum and seen a lot of answers/pics about this subject. I know that every car is different and you will get a different answer/outcome from every scenario depending on what the specs are. Basically what I'm wanting is my tires flush with my fenders. I don't mind if they stick out a little, just not tucked in at all. I'm told by a local shop here after they measured the gap that the most I can run is 20MM rear and 15MM front without rubbing issues. I measured the gap myself and actually got more in the front than the rear. Front= 1 1/8" (approx 27MM) and Rear= 1" (25MM). I want to try and get this right the first time. I feel like with my measurements and the size spacer the shop suggested they would still be tucked in alot. I am lowered on H&R springs and running 20X8.5 all around with 245/35/20 tires all around. Since I dropped it the negative camber has made the wheels tuck in at the top and look terrible. Raising it is not an option since it looks like a 4x4 with 20's. I've seen guys on here with really agressive offsets/tires/wheel combos and they're sticking out of the fender an inch or more. My question is, do they not rub? Or do they just not care if they do? I can roll/pinch my front fenders to give a little more room, but the rears are already flat. This car is my daily driver so I'm not interested in modding it to the point I have to be careful where I drive every day. Just want to get it as flush as possible and still be functional. Any advice would help.
Just keep trying and try saving the images in other formats. If you have a photobucket type of account, linking still works well.
It sounds like you don't want to be running that much camber (unless I misunderstood). Do you have camber arms/toe bolt kits? With H&Rs you really need them. If your alignment is way off I'd be sure to get that taken care of before going w/ spacers since the actual spacer gap will change quite a bit once your camber is in spec. Obviously if you've got the arms & your aligned to your liking disregard this post, lol
Do you have your alignment specs? I haven't heard anyone w/ H&Rs that was able to get in spec staying w/ the OEM parts. Glad your tires are wearing evenly even though I doubt your rear toe is in spec. My B&Gs dropped about the same as H&Rs (I'm at 25.75" to the front fender lip, 26.25" at the rear) and there's no way I could get in spec on toe & camber without the SPC arms & bolts. Maybe you can post pics on imageshack and just post the link?
I'm sure you're planning on keeping your G for a while, it's best to make the investment in the arms and get that alignment correct, or at least close. your tires will be fighting the road rather than rolling with it, plus the drive is better and safer when it's in spec. I'd use the money you're budgeting for spacers and get the arms, then see what your spacer size will be, I'm sure it'll be in the 15mmF & 17-20mmR range. good luck w/ whatever you decide.
maybe these links will work..
left front
http://img220.imageshack.us/img220/8337/frontviewa.jpg
left rear
http://img401.imageshack.us/img401/2056/rearviewg.jpg
left side
http://img811.imageshack.us/img811/3145/angleviewo.jpg
http://img861.imageshack.us/img861/5816/lakede.jpg
left front
left rear
left side
