08 G35 Spark Plug Replacement, need help
Old Jul 19, 2012 | 08:41 PM
G35xTejeda's Avatar
I found a DIY for the Plug replacement but it was for 1st generation Gs. Are the plugs located in the same place?
Where are the plugs located? What tools do I need?
Old Jul 19, 2012 | 09:50 PM
saywat?'s Avatar
lol
Old Jul 19, 2012 | 11:47 PM
kool_yaar's Avatar
THIS DIY for 2nd Gen G's should help, includes what tools to use and how to do it with pics.
Old Jul 20, 2012 | 12:55 AM
vqsmile's Avatar
Yep, pretty much the same; three on either side
Kool, that DIY link is definitely useful, but I'm gonna go ahead at offer this link to a post I made about it in another thread just the other day.
https://g35driver.com/forums/6513164-post15.html
Old Jul 20, 2012 | 01:17 AM
G35xTejeda's Avatar
Thanks! I was able to do it withiin 2 hours.... Did one plug at a time, I have no idea about mechanics but I was able to do the job. I had trouble taking off the throttle body due to stripped 5mm Allen keys.. Everything else was a piece of cake.
Old Jul 20, 2012 | 08:14 AM
mathnerd88's Avatar
How many miles did you have on your G before you changed the plugs? Were the old plugs still in good condition when you took them out?
Did new plugs make your engine perform better?
Thanks in advance.
Old Jul 20, 2012 | 02:33 PM
G35xTejeda's Avatar
My g has 104k. The old plugs were kinda burned out, looked very old and wasted.
The new plugs made the engine turn on without Hesitation and the response seems slightly better. Mileage hasn't improved yet but my engine doesn't feel as forced anymore.
Old Jul 20, 2012 | 02:34 PM
G35xTejeda's Avatar
I did clean the throttle body and maf sensor since I was already in the engine.
And don't forget to reset the ecu and the other procedures.
Old Jul 20, 2012 | 02:36 PM
mathnerd88's Avatar
Thanks! I will have them changed out once I hit 100k. Maybe I'll also clean the TB too, but I don't want to damage anything or have to do a learn reset procedure....
Old Jul 21, 2012 | 02:00 PM
woostar88's Avatar
You can simply reset by disconnecting the battery...
Old Jul 21, 2012 | 02:28 PM
kool_yaar's Avatar
^ u can reset the ecu via the battery method but not the TB 99% of the time.
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
ghost_g35
Aug 7, 2015 10:31 AM
laksjd84
Jul 24, 2015 05:12 PM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
