Year, mileage and what had broken on your car
Old Sep 9, 2012 | 06:52 PM
GNN60GT500's Avatar
2007 G35 75,000 miles
Radio head unit broke- $1200 repair
Problem with gas tank not filling up- $300 fix
Peeling trim
2 catalytic converters- under warranty (would have been $1200)
Need to get TSB done for clanking rear end on acceleration and deceleration
Average? Above Average? Below Average?
Old Sep 9, 2012 | 07:31 PM
bluedevils95's Avatar
Well, 47,500 roughly and now as of today my sport mode just died on me. Good thing i got the extended warranty. I am going to take it in tomorrow.
Old Sep 9, 2012 | 07:35 PM
pattyballs's Avatar
2007 G35x 83,000 miles
All of my repairs were don under my extended warranty:
Interior trim and steering wheel
Heater coil in both seats
2 sets of catalytic converters (now on my 3rd)
steering rack & Pinion
2 ac condensers (on my 3rd)
2 shifter units (on my 3rd)
3 axles
guage cluster
2 sets of speakers (now on my 3rd)
Old Sep 9, 2012 | 08:10 PM
Supremee's Avatar
2007 G35S sedan 90,500 miles.
I dont want it anymore....
No problems but SES Light - Exhaust valve timing magnet retarder... IDK WHAT THAT IS!
Still not fixed (hopefully someone can help)
Old Sep 9, 2012 | 08:24 PM
bkd's Avatar
bkd
2008 G35S 6MT w premium & nav pkgs.
A TPMS sensor failed around 25K.
Now at 40K and the interior trim on the doors is starting to peel and the chrome Infiniti emblem on my engine cover has fallen off.
So far so good.
I'm under the original warranty until December and I'm considering the cost of extending it. This thread might help me make up my mind.
Old Sep 9, 2012 | 08:53 PM
muyrec's Avatar
'07 journey 56k on mines.
1. Emblem on engine cover fell off.
2. door pulls replaced due to peeling.
3. steering wheel bezel trim replaced due to peeling.
4. the lower side instrument panel covers are warping. (these have an updated part number so it must be fixed).
5. passenger door washi trim cover peeled out in one side.
6. Cluster cover warping.
7. a baffle inside the mufflers got loose causing a 'tin can' sound upon accelerating when the engine was cold. sound would go away when hot. This was fixed by buying an invidia exhaust system
And that's it. The car is pretty solid. It's a such a blast to drive it. keeping it for a loooooong time.
Old Sep 10, 2012 | 12:23 AM
Wannabe6MT's Avatar
-MN G Crew-
Peeling trim
How did you know your radio head unit went out??
3 axles
guage cluster
How did you know your cats went bad?? Or a rack and pinion??
I haven't had too many issues. The instrument clusters and door pulls when I bought it at 30k. No problems yet with 55k now on it.
The transmission was replaced due to a 5th gear grind-38k mikes.
Throw out Bearing at 45k.
And thats it. Every things been under warranty.
Old Sep 10, 2012 | 02:05 AM
G3065's Avatar
07 G35 with 86600 miles blue slate.
front arm rests
2 steering wheels
instrument cluster
shifter ****
shifter assembly (DS mode issue)
Other then that the car is in great shape and still going strong...
Old Sep 10, 2012 | 08:49 AM
rpm&my_G35's Avatar
This site (http://www.truedelta.com) is also a pretty good resource for this type of information. I think many of us here have contributed.
That said, when I had a 2007 G35x, traded in with ~48,000mi the car had done:
a) brake judder - replaced rotors and pads under warranty
b) chipped front grille - replaced under warranty
c) chipped front door switch bezels - replaced under warranty
d) steering column replaced because it would move a little bit after it mechanically set into place - replaced under warranty.
On my 11 G37S 6MT; absolutely no problems (knocks wood)
Old Sep 10, 2012 | 09:05 AM
blnewt's Avatar
07 G35 sold it w/ 36kmiles (now has 76k, sold to a friend), only issue was sunroof trim, fixed w/ TSB.
09 G37 40kmiles, no issues other than 2 Auto transmission reflash TSBs.
Paint sucks ballz on both cars tho
Old Sep 10, 2012 | 10:35 AM
GNN60GT500's Avatar
On the head unit, radio started just switching stations on me for no reason- got worse and worse until every couple of minutes it would just switch stations on me
Either it was broken or haunted!
Converter failure- got PO420 code/ check engine light
Just interesting to see some of these posts- I guess Infiniti is closer to being BMW like then what I wanted when I bought it! lol
Old Sep 10, 2012 | 11:20 AM
tehgreatmg's Avatar
'07 G35S 6MT - 86k Miles
No major issues in my opinion.
OEM brake rotors warped; replaced with stoptechs and no problems out of those.
Steering wheel and arm rest trim peeling.
Dash warping on lower drivers side.
Badge came off on engine cover and disappeared. (Anyone know where to get just the badge and not have to buy the whole cover?)
Two clips holding skid plate broke off.
Old Sep 10, 2012 | 11:56 AM
RedBaronK's Avatar
On 3rd compressor starting at 30, 45k
Catalytic converter 45k
Trim 23k
Old Sep 10, 2012 | 11:57 AM
RedBaronK's Avatar
I think the build quality isnt great, but then again beats paying 38k for a BMW 328 that doesn't have as much horsepower.... so much horse power that my coffee cup tips over when I floor the car... lmao
Old Sep 10, 2012 | 12:49 PM
jkat13's Avatar
'08 G35xS, 67,000k
Relatively minor stuff:
1. Front brake judder replaced under warranty
2. Steering wheel bezel peeling replaced under warranty
3. Interior door pulls replaced under warranty
4. TPMS senor failed - replaced under warranty
